Welcome to evaluate the first listing of ANEKIM VC30 (P9)
11 posts / 0 new
youruifire
youruifire's picture
Hi, BLF member
ANEKIM is the first to introduce a VC30 (P9) flashlight. You are welcome to test our product reviews.
The first 10 samples, we will send é to DHL quickly.
For new products, we will have a 20% discount (2088RFWR). For details, please click the link below.
https://www.amazon.com/gp/mpc/A1QCJSZZLDF05C
The purpose of opening this theme is to find reviewers and any comments you have about this flashlight.
Features:
· OSRAM P9 LED, maximum output 1050 lumens, strong concentrating performance
·Tail magnetic design, head and tail double spring design, shockproof, anti-drop, anti-attack, easy to use.
· Full-featured: Click very bright, double-click flash, stepless dimming, low voltage warning, USB portable charging, intelligent temperature control.
· Convenient and easy to use Micro USB charging port design, charging current up to 1A, charging faster. The charging port increases the protective cover, effectively dustproof.
· Anti-reverse design to prevent battery damage against circuit and LED.
·Air-grade aluminum alloy material, military grade oxidation treatment, wear-resistant and scratch-resistant more sturdy.
·Integrated barrel design for more efficient heat dissipation
specification:
·Model: VC30 (P9)
·Working voltage: 2.65V – 4.2V
·Compatible battery: 1×18650 rechargeable battery
· Beam distance: 245M
· Peak beam intensity: 10008cd
·Reflecting cup: smooth cup
·Switch type: side push switch
· Size: 126mm (length) x 25mm (tube diameter) x 25.5mm (head diameter)
· Weight: 96 grams (without battery)
·Material: Aviation grade aluminum alloy, military grade oxidation treatment.
· Waterproof: IPX8,
·Lens: tempered glass, scratch resistant
·Accessories: USB charging cable, O-ring x2, hand strap x1, holding clip
youruifire
maukka
maukka's picture
Last seen: 8 months 1 week ago
Could you post a photo of the LED and give the complete data on it (model, CCT, CRI)? I can only find COB LEDs when searching for “Osram P9”.
youruifire
The picture above is the OSRAM P9 LED from the German OSRAM brand. Big Smile
youruifire
Henk4U2
Henk4U2's picture
Last seen: 11 min 36 sec ago
According to their website, the new Wuben E10 also has an Osram P9 led.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
kikkoman
kikkoman's picture
Last seen: 2 years 3 months ago
This one?
rockfanatic
rockfanatic's picture
hello, some more info or test/review of this flashlight?
Andybibbville
Andybibbville's picture
Last seen: 10 months 2 weeks ago
Amazon says promotion has ended?
John 12:46 “I have come into the world as a light, so that no one who believes in me should stay in darkness.” Genesis 1:3 And God said, “Let there be light,” and there was light.
youruifire
youruifire
rockfanatic
on Banggood description is mentioned Osram P9 and Cree xp-hi v3 led. Whats the true? somebody use/bought this light?
BlueSwordM
BlueSwordM's picture
Last seen: 2 weeks 2 days ago
I don’t know.
Can anybody chime in?
npetike1
Last seen: 9 months 5 days ago
I received the light today. The quality is horrible. The inner spring is already flattened. And because of this, the lamp didn’t turn on with a flathead battery. With a button top battery the light is fluctuating, and after a little knock on the body, the light turns off… The front glass is wobbling, its not possible to properly tighten down. The switch have a very bad clicking move. No memory mode.. No dedicated turbo mode. You can switch only one mode to another around. Not recommended. I’m goint to start an RMA process at Gearbest. Sad
