My first guess is that we’re not talking about a light that would do Blue or Red or Green or White, but one that will do various shades?
I’m guessing that using separate emitters would be simpler, but to keep the beam shape from doing weird things, maybe a flower petal type reflector like the Sofirn SF34 would help smooth things out. Put, say, 3 of each color evenly spread around the light and a white in the middle.
Then, there’s the 4 color emitter idea. Again, to keep a consistent beam shape, I’m picturing three in something like the Sofirn C8F. Will they fit in the place of a standard emitter or are they that much larger?
Would a mag ring work for changing colors? If not, maybe a two button interface - one to cycle colors and one for standard power/brightness?
OK - I’ll go sit quietly in the corner and listen to the adults with a clue now.
Interested. Love the wk30. I much prefer separate leds so we can change the led combination later if we want like the wk30. If they use a dive light host like the sd05 I’d even be more interested.
Thank you guys for your great input, especially to djozz, iamlucky13 and amishbill. :THUMBS-UP: :BEER:
Your feedback is highly appreciated. I will check with Wurkkos and Sofirn to see what they will think about these ideas and get back to you.
So far, my impression is that they intend to develop a multicolor flashlight that can use four colors separately (RGBW) but not at the same time. Thus, I don't think they thought about mixing colors for infinite color options yet. Looking at the possibilities we may get with an appropriate driver would make this of course much more interesting and unique. Eventually, it probably depends on cost effectiveness, actual demand and - not to underestimate - the efforts both BLF members and Sofirn will need to invest to make this a story of success. I'm telling this because we are currently some kind of "stuck" with the SP10S BLF Andúril flashlight that is intended to use a sophisticated NiMH/Li-Ion boost driver and Andúril for firmware.
I think the Dr. Jones driver sounds very promising but we may need to find out how easy or difficult it will be for Wurkkos/Sofirn to get it in high numbers and how the interface can be set up conveniently. In the end, it should be complex enough to offer nice color mixing modes but OTOH not too complex to overstrain users comprehension. I do agree that 18650 is a wise choice in terms of size, current consumption and host options (to reduce additional development costs).
Another interesting option that just came into my mind...
Option 1
LEDIL ANNA optic frosted
center LED: Osram S2WP (with channel mixing?)
6x rim LEDs: Samsung LH351D or Luxeon V2 with HighCRI and 4.500 - 5.000K
Option 2
center LED: Samsung LH351D or Luxeon V2 with HighCRI and 4.500 - 5.000K
2x rim LEDs: XP-E2 red
2x rim LEDs: XP-E2 royal blue
2x rim LEDs: XP-E2 green
channel mixing with those XP-E2 color LEDs possible?
Best would be an optic that is partially frosty (for color LED and floody, diffused beam) and partially transparent for best throw on white light. I don't think these exist but who knows...
Thank you Lux-Perpetua for this interesting topic, I totally agree with the single LED will has its problem in low output and less choice of special wavelengths. Multi LEDs will be the first choice if reflector beam angle will suit for each color.
Maybe we should also ask the opinion of stephenk, this light might be interesting for light painters, and they have very specific needs, nothing that costs extra to make it, just a few things in the hidden firmware like specific strobes. That is: in case special firmware is written for this light.
Make Doble-barrel one. One reflector SMO for throw and the other OP with 4-color led inside. The TIR optics could be placed in between the reflectors with warm floody light (E21As?)
No, I mean 2 reflectors, one next to another. There are already such solutions on the market (Klarus XT20, AMUTORCH TC750, Sunwayman D40C, some Niwalkers). IMHO it’s a little waste to apply TIR to all LEDs. We have to sacrifice 1x% of performance while in case of color LEDs we may lose even more.
Probably, 1stein is referring to something like this...
This host here could be using two separate optics. While the Amutorch TC750 uses both "units" for white light, the idea could be to use only one emitter unit with white light and significant throw (e.g. Carclo 10507 triple optic or 10621 quad optic) and a second emitter unit with colorful LEDs (triple made of XP-E2 royal blue, red and green or as quad with additional UV 365nm light) and a frosty optic (Carclo 10508/10509 triple wide spot frosted or 10624 quad optic).
Supplemental: UV light will not work with most optics as these are made of plastic material that filters most of the UV wavelenghts.
Bottom line: If you want to implement UV light into a multicolor flashlight you need to go for a classic reflector design (or mule design) with glass lenses.
I wouldn’t use royal blue LEDs! There is sufficient evidence that they will damage your eyes.
They pretend to be brighter in specs (higher lumen values) but visible output is similar to standard blue.
Instead of using multiple 7135 for each color LED you might consider a single D882 transistor per LED, I’m using them in my RGBW D4 EDC since January 2018 without any problems. D882 are slower than 7135 so I recommend reducing the PWM rate for near moonlight levels.
I prefer a double head light (not double-barrel but one head at each end), similar to my RGBW Q8 but sized as a D4. One powerful quad head with TIR for a couple of thousands lumens and one head with 4 color LEDs behind a TIR. This would require a special tube which leads the positive terminal of the cell to the rear head (hint: FW3A).
I find double-barrel heads really ugly and I fear that I’m not alone in that. And I do not see why the white led should need a larger reflector than the coloured ones, a EDC-type beam is even preferable for a light like this in my opinion.
