I’m in.
I would like to see a small 14500 flashlight with 800 or more lumens, if possible.
Something I just realized I want… A quality zoomy (prefer 26650, 21700, 18650 in that order) that is under $30 and has ramping instead of discrete modes and no flash modes except for maybe a voltage readout. (TBH, would a voltage flash pattern not suffice as an emergency flasher?)
I’m in.
I would like Astrolux to make compact 18650 light with emphasis on compact size, light quality and driver efficiency, rather than peak lumens.
Similar to Zebralight SC64 - not clone but with similar design ethos. It should have side-switch and anduril
I’m in!
Astrolux could make an affordable headlamp, maybe for airsoft or light duty DIY work at home.
I’m in. I would love for Astrolux to build a high power UV and/or red light. Something with some throw. 21700 preferably
I’m in
I would Astrolux to make a 18650 (to fit protected cell) bike light, 500lumen with no step down for 2hours (3500mah)
I’m in.
I’d be thrilled with a AA/14500 compatible right angle light with high cri and a friendly UI (plenty of good examples here on BLF.)
I’m in
Like to see an 21700 small EDC
I’m in.
Would like to see astrolux headlamp.
I’m in.
I would like a headlamp just like olight HS2 but with 2x18650 battery holder or one 21700 battery.
I’m in!
I want more throw than mf4 has…
I’m in!
Thanks for the giveaway. I would like to see something like the FT02 but with Culmn1
I’m in.
I would like to see a flashlight that has both white emitters but also UV. not as a keychain light, a real one.
I’m in!
21700, 3000-4000k TINTS only!
I’m in!
I would like to see a EDC sized 18350 light in Titanium. Maybe limited edition and numbered.
I’m in….
Astrolux is a 5 star category when it comes to producing quality and affordable lights. Hoping to consider putting an aux or RGB led and type c rechargeable…More Power ASTROLUX .
I’m in.
would like to see more lantern options
I’m in.
I would like an Astrolux built out of brushed aluminum.
I’m in.
Affordable LEP flashlight,preferably 21700 size
I’m in.
The ultimate AA EDC. Slim, strong permanent clip, rugged/reliable, 3-4 well separated levels, tail switch.
