Sure , I was jus referring to the time it was created and with no further replies
With be old batches being sold currently, jon_slider courtesy, I figured there would be some other stuff related to these lights around !
I would only be interested in an extender to use it with 18650s (like these: Sold: Jetbeam RRT-01 18650 extender tube) , not a whole tube. I actually managed to use it with a Convoy or Sofirn tube, but it isn’t water/dust proof :zipper_mouth_face:
I need some help. Don’t have my2019 RRT01 with me and i’m about to order some stuff from KD but i left the notes with ’19 RRT reflector size.
If someone can take meassurement of new rrt reflector that would be great.
Wanna get OP for my other mod.
If it’s posted above please excuse my lazyness.
It was about time to post my poormans 2019 RRT triple mod.
Since i’m not a man of photos i only have 3 of them but you’ll get the idea
First, open and disassemble the head as already posted many times. Remove the driver and MCPCB.
I have used replacement driver from Jetbeam which has longer led wires so instead of soldering extra length needed for triple build, i had to cut them.
Open first beer and start filing 3UP MCPCB…
Since i didn’t meassure anything i had file and check physicaly fitment in the bottom of upper part of the head (see photo)
After 3rd beer MCPCB with emitters was ready for thermal adhesive (glue) and to be installed in the head. I have Phoby2, 2-component epoxy.
Next day i’ve stuffed the original led board opening in brass portion of the head with thermal pads which can be found in KD store (don’t have a link now)
Now Carclo 10507 was about to be filed which i did, again few beers helped me and at last i had a correct size for installatio.
Please note that neither MCPCB nor Carclo were perfect round circle due to hand tools!
Once you tighten the head back on the brass section, the only thing that’s left is soldering led wires, installation of Carclo, original lens oring and lens (with the bezel ring).
And that’s it.it can be done in few hours (1-2h) but alcohol and wife were crucial factirs not to.
Thermal pads are transfering heat from MCPCB to the bezel since i didn’t have heatsink at that time. MCPCB in this build seats high above brass section, in the bezel.
I have to add that one member shortly after sent me machined alu piece according dimensions of the section where stock led board seats and is to be installed when bezel and barss are connected. And of course i didn’t took a picture and i just realized i don’t have optics photo…damn it.
I believe most of you are familiar with the tasks required to be done once you see pics but if any info is needed, just shoot.
Oh yeah, if someone can post dimensions of stock 2019 RRT01 reflector that would be great.
If I understand the question correctly, any led in 5x5mm (xml, xhp50) size or smaller 3.5x3.5mm (xpg,xpl,219c,219b) at around 3v forward voltage mounted on a 16mm mcpcb could be filled down to fit.
A copper mcpcb would be better. Finding one just depends on which led your looking to replace it with.
KD sells a few on 16mm copper mcpcb’s. http://kaidomain.com/Flashlight
The 10mm might even work with out doing anything but soldering the wires on.
you will need to make a decision about what color temperature you are in the mood for
unless you know you like warm, I suggest you go with something cooler… like a 4500k
… I suspect Clemence knows what hes talking about, the E21a LED may not be the right choice. some people like the SST-20
others like the LH351d.
both are brighter and less pink than the 219b and E21a nichias…
(I avoid the 219c, its brighter but for a snob like me, “too” green…
however, moderator007 is a wizard when it comes to sourcing parts… and when he talks, I take notes)
Interesting. I found my Astrolux S41 with the 219C to have the most neutral white light. No green, but this was maybe just luck? Actually, I dislike the Samsung (Wuben E05-I) for its greenish tint at 5000K.
I have both SST-20 (D4V2) and E21A (Folomov EDC C2) at 3000K and am convinced that the color contrast is much better with the latter, so this would have been my choice. A really nice LED! But if it can’t cope with the current of the RRT01, I’ll go for the 219C. Quality of rendering is more important to me than color temperature.
Getting a good bin led is pretty much luck. If your buying a specific bin and are guaranteed that bin then chances are high you’ll get that bin.
If your just ordering a specific color then it’s just sure luck if you end up with a good tint. If tint in a specific color is what your after then I would try someone who gives you the specific bin you want. With out the bin code your playing the led tint lottery. There’s alot of led group buys that go on here just so we can get a good bin led.
There’s also some sellers who specialize in good bin tints with high cri like Clemence.
You might contact Clemence and see what all might be available in either a 16mm mcpcb that could be filled to fit or maybe he has offerings that would work in 10mm. He offers a led reflow service, I think for a dollar.
He also has a store. https://www.virence.com/shop
so far so good
but its not in a 2019 RRT-01, which has higher output
since Unheard is OK with the tint of the 219c, I think your link to the 16mm board w 219c is a higher output option… as long as hes OK grinding down the diameter of the board to fit the 2019 RRT-01
