I have C8A driver that randomly starts flashing as if low voltage warning or something. Usually locking it out then back on resets it but it gets annoying . I know of a few posts about the same problem before. Short of removing the driver, is there a cure for this and has the problem been addressed in later ones?
My Sofirn headlamp just did that. I wonder if a battery swap might help. I haven’t had time to check though.
Oh as in the red LEDs? It’ll be to do with it thinking there’s a ton of resistance - reseat all the springs if possible, and try and feel for other spots that get hot where they shouldn’t. My SP40 did that when I installed a magnet cause I didn’t have the spring siting right; pushed it back in solidly and it was fine.
When is Sofirn going to start using those LH351Ds in more lights? I would but several models in a heartbeat if they used that or SST-20 4000K.
I’m dreaming about SST-20 4000K version of SP31A with direct access (by long press from off) to true firefly mode (3 or 4 lm) and direct access (by double click from any mode) to turbo.
Strobe could be hidden in next double click after turbo.
I love very first SP32’s runtimes. Especially 918hr in firefly mode. I don’t think sofirn has any other light that can run longer on firefly mode.
Did anyone test the 918 hour?
(Quick calculation: 3500mAh/918h=3.8mA. If the driver has no leaks, the MCU eats at least 2mA, so 1.8mA leftover for the led with which you can make 0.8 lumen max, not 3 )
New design, variable temperature color EDC flashlight.
2pcs LH351D 6000-6500K and 2pcs LH351D 2700K
TIR optics, Type C USB port and with indicator.
Very compact 16mm length only
Photo comparison to C8G.
Source: Sofirn’s facebook page
Perfect for 4* SST20 high CRI 21700 version with Anduril (IMHO)
I’m gonna guess… that’s 106mm length? Not 160mm. But definitely not 16mm either
Cool. Good to see more USB-C, and I see the LT1 tint-mix theme is spreading. Mix it to 4000K-5000K and the average should be nice. It beats slicing dogfarts…
Sofirn in the house!
That looks like a winner right there.
Hello Barry,
Excuse me for coming (maybe) late, and asking a question:
Will the SP70 BLF version include better emitter choices, than the current non-BLF version SP70?
Nice! tint ramping? Probably, they directly applied the Lantern firmware I assume.
Yes, you need a special UI for tint control and I don’t think Anduril is designed for that.
I thought Sofirn already had a developed tint ramping UI in one of their lights a while back?
Hope no only black once again
It could also be 116 mm.
With a thinner bezel and powerbank capabilities it would be a must-buy. As it is I find it interesting but not special.
not sure i understand why u want 2 cool white and 2 ww leds??
Tint mixing, and superb dynamic range with 90CRI LEDs.
It’s what the BLF lantern does.
I’m guessing they will install a driver that can control the 2 different tints separately (maybe it comes with such a driver stock?). That way you can adjust color temp on the fly.
Sofirn mentioned a new revision of their Sofirn C8G in the Aliexpress shop with a moon mode an a new Standby Mode.
Does anyone know what die new Standby Mode means? Maybe they removed the annoying instant on when clicking the tail switch?
I asked them on ali but get no answer…
Usually standby mode means you can turn off the light by the side switch. The tail switch continues to keep the power connected.
