Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1492 posts / 0 new
led4power
led4power's picture
Last seen: 14 hours 19 min ago
I never had problems with pads coming off pcb, it seems you are using way too high soldering temperature, do you have any pictures of your soldering work?
You can solder wire to those resistor pads, but be careful, if you are holding soldering tip for too long or temperature is too high, you could easily desolder/remove resistor since it's very small.
Which mosX board and which 6V LED are you using? "M" pad is connected to LED cathode. There should be no continuity between + and M, maybe you've soldered LED rotated by 90deg? You should check LED and MCPCB first, of course driver can't work if LED pads are shorted.
In third picture is Luxeon MZ (3V LED) driven by LD-B4 driver (not LD-B4HV which is >1S driver), LD-B4 has moonlight support so M wire is for moonlight modes.
Buoyen
Last seen: 1 year 4 months ago
Thanks for quick reply! Smile
My soldering is probably the cause Smile
I’m using a regular 25-30W soldering iron without temperature control. Heating the wire/pad until the solder is melted and then let go.
I might have soldered the LED wrong also, but if M is connected to LED cathode there should be continuity between “+” and “m” on the mosx when measure through the LED? Like in the photo:
https://photos.app.goo.gl/7zJkgkEzvu6Ewvh58
Don’t know if this is usual, but the LED lights up when I use my voltmeter on continuity setting so I know the LED is working at least. Just like in the picture when I measure between + and m.
And at first I did connect battery and all and discovered I wasn’t able to adjust brightness or enter setup mode. The LED was running direct drive I guess. Luckily the battery wasn’t full and I jused just thin wires to test with. It was bright Big Smile Big Smile
The LEDs are a XHP70.2 6V on the mosX connected in series with a XHP50.2 6V on separate pcb. Driven by 4 samsung 18650 batteries in series. The driver is the 4s/6A version.
The curcuit seems to be fine when the gate wire is not connected between driver and mosx. When this wire is connected it seems like the FET is shorted or connected somehow, like this:
https://photos.app.goo.gl/y7t1gmPpkZ4z7LgE9
led4power
led4power's picture
 Try to measure exact resistance (instead of continuity) between + and M pads, with LED should still see high resistance. Best way to set LED is to set multimeter to diode test, if LED is ok it will emit some light, but that usually only works for 3V LEDs.
Since you are running 2 LEDs on separate PCBs, how did you connect those PCBs? Diagram for one LED looks ok.
Buoyen
Ok, thanks again!
Will see when I get home.
Btw when I say continuity I mean diode test. Sorry Smile
Added the other pcb/LED to my scheme Smile
https://photos.app.goo.gl/gMhamVpvTYJU51z77
This other LED did come on sinkpad pcb. It’s only the XHP70 og mosX i did myself.
Buoyen
Measured resistanse between + and M. Even at 20M it is out of range.
Tried new driver. Soldered gate very carefully Smile went ok.
Same result though when I have my meter on diode test and measure between + and – on mosx the LED lights up as if the FET is on.
Adding some pictures. Is it possible the LED itself sit wrong on the pcb allthough I cant measure any shorts?
The driver
https://photos.app.goo.gl/zD7FrEAZbGh84Y5cA
https://photos.app.goo.gl/6T5JUNVrtyFr6aAr8
MosX
https://photos.app.goo.gl/K6AEKF3prcprw3Qb7
From led4power website to see how the pads look
https://photos.app.goo.gl/RKm4gKoJFVk25Sef8
XHP 70 datasheet shows what is anode and cathode
https://photos.app.goo.gl/x7qc3BpDYKGLPtYa8
Buoyen
I followed this video on how to flow the LED onto the mosx. Only difference was that I did it in the kitchen using an old frying pan (don’t use it for cooking anymore Wink ).
Used low temperature solder paste. I don’t think the solder on the fet melted while I did it.
https://youtu.be/B3F68ubfBkk
djozz
djozz's picture
Last seen: 7 hours 57 min ago
So your FET is in series with two leds? Does it get the right voltage to function?
Buoyen
Yes it is. Input voltage on the driver is 16V. Two series LEDs in series.
Maybe I should switch them around so the mosx is closest to ground?
But this was my next question: do I need to hook up the battery for the FET to function? I thought it was normally open curcuit. A bit scared to power on after yesterday when I think it was direct drive..
led4power
led4power's picture
Buoyen wrote:
Ok, thanks again! Will see when I get home. Btw when I say continuity I mean diode test. Sorry Smile Added the other pcb/LED to my scheme Smile https://photos.app.goo.gl/gMhamVpvTYJU51z77 This other LED did come on sinkpad pcb. It's only the XHP70 og mosX i did myself.
mosX board should be last in chain from battery + to gnd (or closest to gnd), so if you connect it like in diagram it's not good.
Buoyen
Cool. I’ll try Big Smile
led4power
led4power's picture
Buoyen wrote:
Yes it is. Input voltage on the driver is 16V. Two series LEDs in series. Maybe I should switch them around so the mosx is closest to ground? But this was my next question: do I need to hook up the battery for the FET to function? I thought it was normally open curcuit. A bit scared to power on after yesterday when I think it was direct drive..
FET is normally open (high resistance) but if gate pin is free floating it can be charged for example via testing with mulitmeter and FET will be in closed (low Ohm) state for quite a few seconds even without any voltage applied to gate becasue of gate capacitance.
Actually this is the way I test mosX boards with FET: I charge gate by applying x.xV for 1-2sec, and then I connect mosX board with LED to power supply to + and - pads like standard (non mosX ) MCPCBs.
Buoyen
Worked like a charm! Excellent, thank you. Smile Smile
contactcr
Last seen: 3 hours 10 min ago
Some test fitting while I wait on LEDs
New LD-B4 12A 20MM. The pads are huge on this and easy to solder. Looking forward to finishing this build..
Finished product:
LEDs: 6x LH351D 3500K 90CRI
12A CC mode
~11.55A tail – 3,205lm
FET mode (VTC5D)
~19.4A tail – 4,370lm
contactcr
Was there never a MOSLED Extreme 4*XP*? Only the black board one was made?
led4power
led4power's picture
Yes, no 4xp mosX in 20mm size.
contactcr
The black mosled should be ok with M2 quad at 12A right? Sitting on big chunk of copper
led4power
led4power's picture
Which LEDs?
contactcr
351D or SST-20 probably
led4power
led4power's picture
At 3Amps per LED they are within rated manufacturer current which means they would be ok even on ultra cheap standard dielectric MCPCBs, so black mosled 4x is more than fine.
Buoyen
My new helmet light.
Ldb4 hv 6A driving 1 xhp70.2 and 1 xhp50.2 in series off a 4S battery. CNC milled housing in aluminium for good thermal properties. 3d printed gopro mount. And remote control of course. Looking forward to try it on the trails Big Smile
Next step is anodizing and paint.
https://photos.app.goo.gl/iitiGKdBAruXCwbD8
https://photos.app.goo.gl/sNYXwPNi9yMg6Vkm8
https://photos.app.goo.gl/MjQkugScJjMPFXzb8
https://photos.app.goo.gl/km6Etn64wY469faA9
https://photos.app.goo.gl/bPFP5v5H3x48W7if8
https://photos.app.goo.gl/YtoXnkFL3t3JSvMf9
contactcr
Damn that is fancy. Nice work
Buoyen
Thanks Wink
KevinZA1988
KevinZA1988's picture
Last seen: 1 month 1 week ago
Neven, is your website down for maintenance? I’m struggling to get it loaded.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Emisar D4, Fireflies E07, Jaxman E2L, Manker MC13, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II.
Most of them have been modded! =)
https://photos.app.goo.gl/JaJaDv4V838AEJf39
led4power
led4power's picture
Hosting provider issues, I hope they will fix that today.
KevinZA1988
Thumbs Up
led4power
led4power's picture
It should work now.
KevinZA1988
Thanks it’s working…
flightless22
flightless22's picture
Last seen: 1 day 2 hours ago
The server is up but the store is not accessible.
led4power
led4power's picture
It's back now, but until some updates are done I'm not sure how long it will work (again), so if you plan to order, it's good to do it now.
led4power
led4power's picture
After some updates web is working stable now.
Luxeon MZ (on all PCBs), Osram IR and Luxeon IR  are on clearance sale:
https://led4power.com/product-category/leds1/lumiledsluxeon/luxeon-mz-4x2mm2-die/
https://led4power.com/?s=4715as+osram&post_type=product
