Sky Lumen Nguyen Flashlight
253 posts / 0 new
vinhnguyen54
Last seen: 1 year 3 months ago
Hello All,
I am not sure if this is the right place to share my Sky Lumen Nguyen Flashlight Project. If its not let me know and I will move it. My team and I have been working on this project for about 1 year now. There were delays here and there but I think we are finally almost there and I am very excited to share it with all. I am not trying to sell anything in this thread. However if you are interested in the project you may email me at SkyLumen54@gmail.com for more info. I also understand there are tension between CPF and BLF but I do hope that reside elsewhere but not between flashlights enthusiasts worldwide. I am just here to share a common passion with all. Cheers!
View post on imgur.com
Proto V3 Testing Sample Specs & Background:
Unpotted light engine – Let’s see if driver can take the hits
Proto V3 is made of 6065 Aluminum not 7075 Aluminum: Not as tough as 7075 but a bit better heat sinking.
First run of 30 lights will be 7075. 2nd run of 30 will likely be 2011.
Testing light engine will be a Quad White 2 + DriverVN4 + FS54 + Copper Retainer. Set to a simple 2 level for function check.
Dual Orings on both ends of the body installed
Triple Orings on body installed
heavy Duty 2.25mm thick Blue boot installed
NO-OX-ID electrical conductive lube over all Orings except for the 3 on body
Dual side Antireflective 3mm tempered glass
Optional suspension flat oring behind glass installed
Standard matte Ti pocket clip. Screws and clip glued in place.
HA III finished. Production body parts will be sandblasted before HA III over for uniform look & gold alodyned over threads to prevent corrosion.
Clicky tail cap + standard head installed
Manker 21700 5000mAh Protected
Loaded weight 11.5oz
135.mmm Long
Head & Body 33.4mm thick
Tail cap with clip 39.3mm thick
Sky Lumen Nguyen Packaging
https://youtu.be/E4dULDJ9FUI
Test 1: Bucket Water Dunk
https://youtu.be/Iot-buLtQr0
Test 2: High Water Pressure
https://youtu.be/M_fgcXTKAiE
Test 3: Corvette Driver Over
https://youtu.be/uqZ8EFqm9Jc
Test 4: Before Test Recap
https://youtu.be/WLV0gghpnPw
Test 4: F150 Driver Over
https://youtu.be/_TH8vUlMxXI
Test 5: Heat Test
Test 6: Freeze Test
Test 7: Impact Test
Test 8: Final Operation & Seal Test
Test 9: How to Kill SL Nguyen?
Edited by: vinhnguyen54 on 09/09/2019 - 12:18
anonymous_user
Last seen: 7 hours 59 min ago
Any way you can just share the info about the light here?
vinhnguyen54
I sure can. I will update post 1.
Slayer1
Slayer1's picture
Last seen: 5 hours 34 min ago
Following.
chops728
Last seen: 1 hour 8 min ago
I’d be more worried about my Vette than the Light—————————— Facepalm
SKV89
Last seen: 2 weeks 10 hours ago
I would like to know more about the emitter options. Saw at CPF that there will be a 14 emitter option. Is that going to be E21A or 3535 emitters? Also please keep an eye out for BlueSword’s dream bin LH351D emitter. I would like those very special emitters to make this light even more special.
saypat
saypat's picture
Last seen: 3 days 9 hours ago
… that packaging is genius!
when will the remaining tests be up on Youtube?
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 16 hours 5 min ago
Linear CC, PWM’ed FET or other type of driver?
Emitter options?
Driver LVP and reverse polarity protection? Protected cell seems an odd choice for a quad hotrod (at least I assume its a bit of a hotrod since you made it Big Smile )
aginthelaw
aginthelaw's picture
Last seen: 1 hour 2 min ago
Can we start with the copper version right off the bat? Fine, I’ll take two. The clip actually is such a nice minimalist design, gives it a post-modern look. Designer is an artist
never fear shadows…it means a light shines nearby
vinhnguyen54
XP size footprint for the 14 LED option Wink
vinhnguyen54
It will be a while until I can do runs with exotic metals as collectible but it would be cool to make a few.
SKV89
Love How does it fit though? That will be mule for sure right.
vinhnguyen54
That’s the fun part Wink
vinhnguyen54
Nichia
Last seen: 8 months 3 weeks ago
14 LEDs??!! It’s 100% Mule and I am in if you show us some pictures
Nichia 219B
bmengineer
bmengineer's picture
Last seen: 10 months 1 week ago
What made you decide to go with tube walls over half a centimeter thick?
Find all my reviews of flashlights and more gear at www.bmengineer.com
vinhnguyen54
This light engine is in design phase. Was going to do 16. But actually might reduce to 12 to improve trace width.
vinhnguyen54
Its only 5.77mm at its thickest with out threading
vinhnguyen54
BurningPlayd0h wrote:
Yikes guys, he means 14 options for emitters, not 14x installed in the light.
No. I mean 14 (or 12) installed in the light. Light engine option wise there can be like +50
vinhnguyen54
I got this budget Infared Thermometer on Amazon for number 5 heat test. Seems off. For example my wall seem colder than 72F and, my skin less warm than 88F, a metal surface I heated up that is burning to the hand was only 200F, icecream in the freezer at a low 17F. I guess worst case we will just use it as a guidance on temp changes rather than accuracy. I am sure someone here got one right? Are these numbers way off?
contactcr
Last seen: 16 hours 11 min ago
the wall could be right. you can try your temple or the inside of your mouth, should be >90
problem is two things though, these are terrible with taking temps on reflective metals and second where that laser pointer is and where it’s actually measuring can be pretty far off on something as small as a flashlight
vinhnguyen54
By the way its crazy how much adrenaline I went through. Doesn’t seem much on video but I was crazy nervous and excited. Off camera we did a test run over a “normal” light and yeah it was crushed. That made me soooo worried!
I was thinking if the head got crush then I will be VERY screwed! I wouldn’t know what to do. Literal devastation. I am so happy we made it this far. In fact I couldn’t sleep more than 4 hours last night thinking about everything and what’s next. Whooo Smile
twisted raven
Last seen: 1 day 4 hours ago
That thick wall of 7075 aluminum might as well be a solid chunk of steel!
I hope you can keep it 7075 for future runs as well.
And yeah your voice cracked quite a bit during the videos you definitely were full of nervous excitement.
vinhnguyen54
Tested Proto V3 is 2011 which is softer than the First 30 Production 7075.
I am guessing the 7075 will handle the physical abuse a little better. But also hoping the 2011 will handle the next heat test better.
texas shooter
Last seen: 7 hours 38 min ago
Silly question, are these taking modular drop-ins?
BurningPlayd0h
What is the advantage of that many emitters in a host this small?
Also a good final test would be a drop/throw test I think, impact resistance would go a long way to showing durability too!
vinhnguyen54
This specific will be revealed close to the release with official production pictures and details.
vinhnguyen54
The more LEDs you have the better the efficiency at lower levels.
Take the X80GT for example with its 18 XHP50.2. This light can run 4000L level SUPER LONG heat wise vs a light of similar mass running a single XHP50.2 pushed to 4000L.
More LEDS = Greater turbo lumen. Always exciting to push boundaries.
More LEDS = more enjoyment while the LED is ON or OFF Wink
This specific light engine will also be especially useful for photography, videography, diving, diffuse lantern, ceiling bounce, woods navigation, attics, real estate illumination…
Yes impact tests is very important and it’s test number 7. Still have 5 and 6 to do today though. Smile
BurningPlayd0h
I totally missed “impact test” in the list Facepalm
I’m sure it will pass these next tests with flying colors, hopefully you can get some sleep soon then haha!
vinhnguyen54
Actually running a 5100mAh 21700 cell with a quad white2 is no joke. The light will get WAY TOO hot to hold at some point and I am really not sure if the all the internals can hold up to the heat. 18650 volatge sag faster so the max heat period isn’t likely too long but 21700 should last a bit longer. Gotta set this up outdoor to be safe. Video will be boring to watch but the test is crucial to see how the electronics hold up.
Anyone want to guess how long it takes for the light to get to Too Hot To Hold?
twisted raven
With quad Osram CSLPM1.TGs I’m guessing 3 minutes or so considering the amount of aluminum. Of course too hot to hold is subjective, so I can see it being extended out to 4 minutes.
