I had suggested a body tube similar to the S12 or one of his others to have his style to it. Also asked for a possible finned head and double o-rings.
I’d be interested.
I’d almost certainly pick one up.
My funds are pretty tight but this would shoot straight to the top of the list. I definitely like the idea of some nicely done fins and double O-rings. I’m afraid I can’t really be much of a help with design aspects as I’m just not knowledgeable enough. I firmly believe that we should not infringe on patents and the like but it does seem to me like this should be doable without doing so.
In for few
I would buy one.
Thanks for replying. It’s not really a thread of BLF’s design but of the desire for Convoy to produce. Simon has offered to update the 502B to 21700 size. This design how ever only allowed its head assembly. The tail piece was notorious for cross threading as it inserted into rather than over the body. We need to show interest and that this is not a dead concept to get a true P60 format with Convoy’s style.
Hm? Mine all had/have glassy-smooth coarse triangular threads that screw in perfectly. They’re like pipe-fittings.
I don’t think I could cross-thread ’em if I tried.
I always loved the ’502B, EDCed one since I carried any light on me at all.
I would definitely be in for some. I love the P60 for moderate builds and beat around uses!
Please help this happen!
If we do this, and make an upgraded ’502, please please please please please keep the original rounded tailcap. Ie, where the tailcap itself is rounded, and the switchcap is similarly rounded and flush with the tailcap itself. Not the common squared-off tailcap, “moat”, and then pill-type switchcap like on every other light in existence.
The original rounded tailcap lent the ’502 a unique styling, made it easy to press even with gloves, and who cares if it’s not able to tailstand. The L2M (and most Solarforces I can recall) with protruding button was never able to tailstand, and no one P&Med about that.
It’s a bit hard to see with glare reflecting off the tailcap, but like this:
You should be able to draw one contiguous arc from edge-to-edge of the tailcap, with the profile of the rubber switchcap following that arc.
All depends on the pocket design… I would be in for a few….
I would definitely be in for one but depending on the design maybe more.
I for one think tail standing is important. It is very hard to use a largish light when you are the only person and have to use both hands to work. I have always migrated towards the Solar Force tail caps that allow for a free stand. Now, I do not like the totally encircled buttons, but the ones with cutouts still allow for gloved use.
I’d love to try one! Maybe something with a tactical look.
Actually, I think those with the cutouts are the absolute worst, yet every light and its grandmother has them. :confounded:
If they don’t line up with a side-button, a pocket clip, etc., they’re just downright awkward., and in at least one light I have (UT20?), it just bites into my thumb trying to use it while still being able to access the side-button.
And they’re much less stable when tailstanding vs a full-circle, especially on a slightly-tilted or otherwise irregular surface.
The way I carry the ’502 (several years, daily), the clip goes under my knuckles and is sort of a natural grip (like where brass-knuckles would sit).
Stick “ears” on the cap that don’t line up absolutely perfectly with where my thumb rests, and I won’t buy even a single one. And I’m not about to half-twist when I want to press the switch, then half-twist back when I’m done. Yecch.
I would be interested
Any updates on this or not enough interest?
Same here, gladly would buy…
but if it’s like almost perfect
Meaning no sharp edges
No hard knurling like C8+
firm clip (not s2+ type)
18650 preferably due to diameter
Forward clicky
Read the OP…Thread is for a 21700 P60 Light….
I’d like to see some slightly more aggressive knurling than the S2+ like what was done on the YLP Unicorn 1.0.
