Lumintop FW1A discussion and review
Ooooooo
Updating the first post now!
Thanks Active A1 for the info.
Tailcap switch makes sense when holding the f/l raised the “tacical way”. I’m doing this to reduce shadows, usually to being able to light up something distant. For floody lights, I don’t want anything else than a sideswitch or magnetic ring, therefore the D4V2 won the race (for me!) If there was a FW1 with maximum throw in this class of lights (no OPR), I’d likely buy it … after extensive beta testing [by its customers, as usual].
Looks like the choices are:
Luminus SST-20 4000K
Nichia 219C 4000K
Cree XPL-HI 1A (CW)
Cree XPL-HI 3D (NW)
Cree XPL-HI 7A (WW)
I went with XPL 3D. Later easy swap with 351D and when SS bezel show up, the whole section will go to titanium FW3T
ActiveAl, according to the specs, the XPL has more lumens and more throw.
Tint and CRI is what am after. For throw i'll put White1 in
Nichia and 7A won’t add to the cart, I think only the other three are available options.
Now it seems it’s gone
Try this one:
Yes, link has changed - amended my previous post.
Wait. These are live?!
YEP! :partying_face:
Is 1200 lumens for the XPL and 700 for the SST about what everyone was expecting?
I’m surprised the candela numbers are what they are.
I guess those sound a bit optimistic. I was hoping for more lumens.
I hope we get new colors. I already have two grey FW3As. I should have waited until the colors came out, I want that army green one. I was hoping they’d use the same colors for this one since they are already producing them and the lights share 2/3 of their anodized parts.
Based on datasheets and testing I’ve read, aren’t those flux numbers only for top of the ramp?
I think FET turbo should be higher than those numbers are. Or have they used some different firmware version with FET limiting?
For example SST-20 datasheet (pg3), a middle of the road flux bin is under 700lm at 3A 85*C.
And another examples:
Maukka tested SST-20 4000K J4 CRI95 to do ~690lm at 2.8A. (~1000lm at 5A)
Texas_Ace tested XP-L HI 1A V2 to do ~940lm at 2.75A (~1400lm at 5A)
Any dimensions of the reflector?? If this won’t fit some of the regularly available optics without too much trouble I’m not buying it.
