The main difference between my posts and SKV89 posts are SKV89 posts are from someone who knows what they are talking about where mine are from a technical moron who just loves nice flashlights.
Mr. Larry forgot his username so he cant log back in to post. Does anyone know how to recover username from an email?
top left “contact the admin” probably a good start
SL Nguyen Flashlight Torture Test 5: Heat Test
Time in Min until “too hot to hold”: 7min
Time in Min until peak temp reached: 11in
Can circuitry handle heat nonstop? YES
Max start up lumen: 2650Lumen
Test ending lumen: 1890Lumen
I assume it’s a FET driver but I would expect slightly higher max lumens so it makes me think maybe some resistance there.
Not a big deal, it might be worth it to allow the light to run cooler. However, I would run the turbo again for a few minutes and unscrew the light and see if those springs are getting hot to the touch. If they are they might sag your springs or kill your switch over time?
IDK something to consider.
All noted
@vinh, are you using a mechanical switch, or an electronic tailswitch?
Mechanical
Why does your quad w2 d4svn produce 4600 lumens and this quad w2 only does 2650 lumens?
Nice work Vinh! Definitely interested in this. Been following your website & Youtube channel for years.
Likely low drain cell. I will try another unprotected.
Nice work Vinh! Definitely interested in this. Been following your website & Youtube channel for years. :+1:
Thank you!
Good observation. I would like to know the reason too. Thought it’s a FET driver.
Thanks Vinh-- I'm back alive! Again, nice work trying to destroy it. I will be surprised if a 9mm hit on the 7075 kills the light, as long as it isn't held fixed. If the light can absorb the hit by moving it should be able to survive it, but not without reasonable messing up of the finish, much like Phuong did with her burn-outs. It has the advantage of almost certainly deflecting one way or the other leaving energy in the bullet, and if you were to score an absolutely perfect hit on the peak of the radius you've hit it where it's strongest in terms of not deforming and should really send it for a ride, again, like the burn-outs did. Not exactly a practical test in terms of what might be a possible failure, but certainly impressive if it handles it. The 6061 the prototype is made of is very soft. If Phuong did the same thing to a 7075 version it would certainly scratch it up, but the big gouges you got in the 6061 would definitely not be there. As long as you don't mind messing up the finish a bit, feel free using it as a hammer.
Thanks Vinh— I’m back alive! Again, nice work trying to destroy it. I will be surprised if a 9mm hit on the 7075 kills the light, as long as it isn’t held fixed. If the light can absorb the hit by moving it should be able to survive it, but not without reasonable messing up of the finish, much like Phuong did with her burn-outs. It has the advantage of almost certainly deflecting one way or the other leaving energy in the bullet, and if you were to score an absolutely perfect hit on the peak of the radius you’ve hit it where it’s strongest in terms of not deforming and should really send it for a ride, again, like the burn-outs did. Not exactly a practical test in terms of what might be a possible failure, but certainly impressive if it handles it. The 6061 the prototype is made of is very soft. If Phuong did the same thing to a 7075 version it would certainly scratch it up, but the big gouges you got in the 6061 would definitely not be there. As long as you don’t mind messing up the finish a bit, feel free using it as a hammer.
So nice to hear from you Larry!I know you are super busy so very nice for u to drop by and join us.
At this point I will have to sacrifice a serial production 7075 sample. My military friend already got a military vehicle set up for the next level Run Over video. I will also start small with PCP air rifle then .22lr and up. If the light survives 9mm I consider it a major success. We have plenty of more potent calibers but that’s too optimistic. Cheers!
How about this one Vinh ——————- :smiling_imp:
Need a SLN AR500 Steel version for that
What a funny video haha Vinhs light prolly can handle only one of those bullets. I wouldnt risk shooting it twice. Haha
