LOL your post is the one which deserves facepalm. Read it again - you ask to remove charging, remove advanced UI, remove indicator light.
What else do you want to remove? Maybe the button? Maybe remove the LED to make it simpler to mod. Maybe remove the knurling so user can do his own pattern…
Like I said, I think you want different product. You want kit or DIY product. That’s fine, everybody has his preferences. Buy that. Don’t ask that Skilhunt change from consumer product to DIY product.
I suggested there are other ways of making a good light. And came up with a compromise. If one doesn’t want indicator leds he or she can remove them - I did so. If someone wants a model without charging, there is the H03 model and if someone want charging there is the H03 RC model.
The UI of the H03 if more fine - very muggle friendly, actually almost ideal. With “advanced” UI i meant Anduril. A lot of people here would suggest it here and some more “regular” companies slowly start using it, like Sofirn. It’s terribly unfriendly for non-flashohilics.
No, I don’t want a different product or a DIY kit. Or does switching from red locklite to the easier removable blue locklite make it a new product? Please read my posts carefully.
The whole point I’m trying to make is that Skilhunt can make their products, with minimal (zero?) extra costs in such a way they can satisfy both regular consumers (priority), flashlight enthusiast and modders alike, thus creating a bigger target group, thus making more profit.
We always hope that we can combine more different needs, easy-to-use products to meet the needs of regular consumers and some of individuated needs, this is not an easy thing. Also we have to consider some of the difficulties in mass production.
We glued the head and tube, because some of consumers not really good at DIY or repair work. If not glued them, the driver board may be damaged if it is not careful. That will bring very bad feeling to consumer.
The Anduril UI is very interesting, but in some regular consumers, it is too complicated, that is why we trying to make A & B groups mode to meet different needs.
We really appreciated more discuss to know more about your needs and try to find a better solution.
I’ve seen you post these for 50% off before so I’ve been holding out for that deal again, preferably on AliExpress . Is this the webpage for the H03R RC
Is the charging function part of the driver or a separate board? If it’s part of the driver then I don’t think I want one anymore as I may swap the driver in the future.
Still holding out for 50%+ discount on H03 or H03R on AliExpress
50% off: 1 pcs available everyday for each product.
save $10 for the order $100+
save $15 for the order $150+
save $20 for the order $200+ click here to join
