So I am still in a search for small zoomie host with glass aspherical lens, 18650 cell only (1” tube), andodized threads, without redundant parts like usb charging port…
So far only OTR Z821 has all this qualities… Looks almost perfect… But manufacturer not available for communication. And they probably discontinued Z821…
If lens are glass one and if it has anodized threads (important safety feature for light) it can pass…
But I think it has plastic lens because it has short zoom walk of only 0,4in and of course they are not showing tailcap threads.
The LED is a little higher on the DTP MCPCB so it doesn't focus but it throws just fine.
Update: I went for the harder driver, Convoy 6A, 4 mode, and despite the removable pill shelf, it transfers heat really well. I am using a LH351D on DTP MCPCB and added thermal paste to the threads that hold the pill in place. There's probably a way to fix it but once the stock driver is removed, the USB charging function doesn't. The built-in charger is not that good anyway.
Anyone know of a pocket clip that works for the Nicron N81?
I probably wouldn’t use the light without a pocket clip.
It appears that you have to go through the blinky modes as part of the mode sequence and can’t avoid them without turning the light off for a moment before you get to them and then turning the light back on to get high mode again. Is that correct? At least you don’t have to go through the blinky modes to turn the light off.
I am proud of the latest finding.
Some may remember Aleto N8. With 108x24 mm size it was one of the smallest 18650 zoomies ever manufactured. Firelight2 modded one to create probably the smallest 18650 zoomie ever made.
Aleto N8 was availabe for sale only for a while and disappeared years ago.
Now I found a Yaoming light that appears very similar but, a sign of the times, comes with a USB port under the bezel.
Sadly, so far I found 0 information about it outside of what is on the sale page. Among others - I don’t know the size.
It is not present on Yaoming website and I failed to find other sellers. I asked Yaoming about it.
Anyone managed to find small zoomie host with glass aspherical lens, 18650 cell only (1”, 25mm tube), andodized threads as very important lock out safety feature, without redundant parts like usb charging port?
Only 1 light with everything mentioned is On the Road Z821 which seems discontinued…
