Disassembly Astrolux FT03 - What Is Inside The Best Performance Flashlight In The World
19 posts / 0 new
vietnamreviews
Lexel
Lexel's picture
Last seen: 1 year 3 weeks ago
scosgt
Last seen: 1 year 1 week ago
You got that right. That was painful to watch.
vietnamreviews
Lexel wrote:
you need a better soldering iron
those are great
https://de.aliexpress.com/item/33010531048.html?spm=a2g0o.productlist.0....
Thank you so much my friend. Wishing you a great day.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 2 hours 35 sec ago
Mine was also a pain to take apart i think they used lead free solder on the MCPCB.
Also using an iron tip with a flat bottom help heaps in bigger lights.
vietnamreviews
vietnamreviews
That price is 40$ in Viet Nam. Is it good enough. Thank you my friend
https://www.aliexpress.com/item/32829734137.html?spm=a2g0o.productlist.0...
will34
will34's picture
Last seen: 17 hours 39 min ago
Best performance flashlight in the world?
vietnamreviews wrote:
That price is 40$ in Viet Nam. Is it good enough. Thank you my friend https://www.aliexpress.com/item/32829734137.html?spm=a2g0o.productlist.0...
These soldering iron work fine i used a Yihua clone since 2015 but its not working right any more. So i upgraded to a similiar model model as Lexel posted these soldering irons are a newer technology they have the heating element built into the tip for a better more precise temperature control and heat up much faster.
I also bought a hot air gun that was a Yihua clone and it was a bit dodgy as it has no earth connected at all so just be careful on what you buy. Id probably tray more towards the Yihua brand more than other clones.
If you have a look around you can find them cheaper. Similar to the one posted just smaller and cheaper.
https://www.aliexpress.com/item/32950636875.html?spm=a2g0o.productlist.0...
scosgt
This one has worked great for me so far on 5 flashlights.
soldering iron
Lexel
Lexel's picture
soldering iron
its garbage when it comes to MCPCBs
you need one that can supply a lot of heat quick, so the thermal resistance needs to be low as well as a good heating element
usually the best ones are where you have the heating element being one piece with the tip and then have one with thick short tip
the Hakko clones are basically a DTP soldering tip
scosgt
I was able to reflow two emitters with no problem at all.
One was on a S70S, which has like a 50mm board. Worked like a charm. And takes the wires right on and off.
It does have a heat element that goes all the way up, the tips are hollow and slip over it.
vietnamreviews
I thinks Astrolux FT03 is best P/P
vietnamreviews
Thank you my friend
delete
Last seen: 1 month 1 week ago
agree.
Tom_182
Last seen: 4 months 1 week ago
Hey,
since you have taken it apart. Can you please tell me what diameter the LED pcb has?!
Thanks and best regards
Thomas
scosgt
Tom_182 wrote:
Hey,
Thomas
That looks similar to what is in the S70S which is something crazy like 50mm. I looked at mine. Way bigger than 20mm or 32mm
vietnamreviews
Tom_182 wrote:
Hey,
Thomas
My friend. MPCB has size 25.5mm. I have also replaced the SST40 leds with XHP50.2.
vietnamreviews
I also replaced the power cord with the 18AWG wire after replacing the XHP50.2 leds. This is the Astrolux FT03 version using SST40 leds.
