I’ll have to think about whether to buy the powerbank, though.
It charges cells correctly, accepts protected 18650s and has a much better quality USB output than most combination devices of this type, but none of my cells are rated for charging at 2A.
I wish Xtar had built a 1A charging option in, perhaps as a little switch in a recess under one of the cell slots.
My cells are protected, but the 5mA discharge at 2.4V cell voltage doesn’t fill me with joy, either.
Some of my cells don’t trip until they hit 2.2V - 2.3V, which is fine at high load when you can rely on the cell voltage rebounding to avoid damage, but it’s far too low at 5mA discharge when it hardly rebounds at all.
Not good if I deplete the powerbank whilst travelling and it’s a few days before I can charge it again.
Now that I think about it, I generally use 18650s, so I could fit a little piece of plastic or silicone sheet in as an isolator if I didn’t want to have some other container for the depleted cells.
I’ve been looking forward to this test, and appreciate the insights it provides.
XTAR did much to address the weaknesses of the PB2, and while not perfect, what other product out there can offer the combination of capabilities it has? Or better it? From a widely distributed, reputable brand name?
HKJ
So if I wanted to use a solar panel to recharge the battery’s once the solar panel quit charging due to clouds or whatever it would need to be powered cycled to resume charging?
Thank you
