I trust what you are saying Clemence. But something is definitely up. Could there have been a mixup with some higher CCT ones in the same drawer when they were built, or just a different bin/batch?
BTW, both my quads perform same.
As for the profile pic, I believe the camera was set to 5000K as it should have been, but I can’t be sure anymore.
Forgot Joshk tested the LED at max 2A. That’s beyond the 1400mA limit for E21A. So, that’s normal. Maukka tested the LED according to Nichia’s binning current at 700mA.
With and without optic or reflector makes a very big difference in both CCT and tint. Here are two examples with the SST-20 4000K. Bare emitter is always much cooler.
Like the current, and the angle at which you measure the bare led. A diffuser like dcfix will average it somewhat but will still only catch and diffuse less than half of the light. Moreover, a any diffusor causes loss of blue light and warms the tint because of blue scattering more than the other wavelengths. Using optics selects other parts of the light again.
The only way to measure average tint is with an integrating sphere coupled to a spectrometer. It integrates the full 180 degrees of output and the sphere can be characterised by measuring the colour-specific light loss over the spectrum and correct for that. Maukka is the only amateur I know of to have that setup and post results with it.
I gave the DC fix a try today. Too close, and it doesn’t diffuse well. Too far and it doesn’t catch the warm light. It needs a reflector. I made a 13mm high reflector for it, but the light from the E21 is so concentrated it was still too close. Drr. I’m not sure if I will continue the project, since the E21 hates 2amps anyway.
