Is this a genuine Samsung 30Q?
13 posts / 0 new
HenrysCat
HenrysCat's picture
Last seen: 1 day 12 hours ago
Bought 2 of these from eBay, advertised as Samsung 30Q's, what you think?
https://i.imgrpost.com/imgr/2019/09/15/Samsung-30Q-IMR-18650.jpg
My test equipment is not the most expensive but seems pretty good,
https://i.imgrpost.com/imgr/2019/09/15/Samsung-18650-30Q-test.png
Lexel
Lexel's picture
Last seen: 6 months 3 days ago
definitely not a real 30Q
on the left side it should have 2 rims in the body
you can clearly see it on HKJ´s website comparator pictures
https://lygte-info.dk/review/batteries2012/Samsung%20INR18650-30Q%203000mAh%20%28Pink%29%20UK.html
BlueSwordM
BlueSwordM's picture
Last seen: 2 days 9 hours ago
Of course not.
That downward curve is way too steep, indicating that it is not a 30Q.
Could you please take a photo of the top terminal of the battery?
hIKARInoob
hIKARInoob's picture
Last seen: 5 hours 10 min ago
BlueSwordM wrote:
Of course not.
The horizontal is [h], and not [mAh], so isn’t this ok?
Pete7874
Pete7874's picture
Last seen: 2 hours 45 min ago
In addition, your reported capacity of only around 2400 mAh seems lower than expected. You should be closer to 2800-2900 mAh.
lightdecay
It does not look the same, but there is only 1 photo. Performance is significantly below expectations. Either it is not a 30Q, or it is nearing the end of its life.
Can you post a photo of all markings on your batteries, and what the top of the battery looks like?
Did you measure the amount of self-discharge after you charge it and leave it for 1-2 days?
fran82
If it helps…
I have 8x samsung 30q that I purchased at banggood about 2 years ago. I noticed weird behaviour..
They have the two rings in the photo.
When I received them… The resting voltage was 3.8…
I used 4 of them and left 4 not used (storage condition.. Same voltage as they were received.. Not touched)..
Ok… After one year.. The 4 that I was using are now dead… And they have had light use in powerbanks.
The other 4 left unused.. Now have a resting voltage of 3.3v. I tried one.. And it is dead too…
I also have in storage condition other brands such as sanyo, keeppower, panasonic… None of them have died. All of them have a resting voltage between 3.6 and 3.8v after being more than 4 years in storage…
Something is wrong with the samsung 30q’s
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
WalkIntoTheLight
In my experience, I think BG does sell genuine 30Q’s, though (at least) the button-tops are not the best quality, probably B or C grade cells. The flat tops I’ve bought (around 8, IIRC) are still performing well. I think they’re around 2 years old, so should be the same stock as the ones you have. Strange that yours have died so easily. It’s certainly possible they got some fakes in there; you can’t be sure that they don’t switch suppliers to someone slightly cheaper and therefore get fakes. But dead completely sounds worse than fakes. Even fakes usually hold a charge.
If they’re like some of my Banggood button-tops, they developed fast self-discharge. That might be what happened to yours. Crap cells, though I thought it was just there button-tops. Low-grade 30Q’s, IMO.
HenrysCat
HenrysCat's picture
Here is the top, no other markings anywhere.
https://i.imgrpost.com/imgr/2019/09/16/Top.jpg
I just removed one of the silver stickers to reveal this.
https://i.imgrpost.com/imgr/2019/09/16/Side.jpg
d_t_a
Last seen: 13 min 19 sec ago
genuine Samsung (can be noticed on 30Q and 25R and maybe others) should have faint markings visible underneath the wrapper (assuming without tearing up the wrapper)
they form part of the date code as mentioned here:
http://budgetlightforum.com/node/19484
niajef
Last seen: 1 month 8 hours ago
is there such a thing as protected flat top 30Q? or just protected flat top period? i thought all protected cells are button tops
Cythras
Cythras's picture
Last seen: 1 day 6 hours ago
I used to have (~8 years or so) some flat top silver wrapped protected Ultrafire 18650s. They had what looked like a reterminated flat top with a conductor that ran to the negative terminal and a very thick gold PCB. That being said, It looks like they just used whatever photos of a 30Q they had on hand.
niajef
but does such thing even exist for 30Q though?
