New . . . from the house of E(1320) - the Shadow EJM05
Can you do me a favor and check the amperage draw when the batteries get down around 3 volts each, please.
I could have kept that light for a week and played around with it. It looks like it going to take me a couple months to get more of those drivers and you got the one and I only I bought for testing. I was so excited about how well that thing worked, I did minimal testing before I sent it back to you.
You could have kept it for a while. (glad you didn't) Cool
Will it let me take them down that low? Maybe I misunderestistood the question?
How come they're so hard to get?
Foy
PM me if you need another one or two with which to 'play.'
XtheHoarder
How come every time I need something you have like ten of them in a box somewere? Were do live again and when are not going to be home............um I mean thanks for the offer PM sent.
Is anyone else having problems trying to create an account or looking up shipping costs from this web site?
Nice work Foy and E1320 (I wish you lived in OZ- feel like moving downunder?)
E1320. Is this driver or something similar available elsewhere as I cannot get the website listed to load correctly if at all? My main issue is that my light does not have memory.
LCKLED is been down for a couple days, I have no clue why.
I got a similar one from KD but it's a 5 mode there are apparently at least 4 different versions of this driver with different micro controllers.
I will wait as I do not desire to have blinkitty modes.
They would only let you buy one, E?
This is seriously the coolest driver I've ever seen.
Foy
I ordered six different drivers from various vendors. The one from LCKLED was 3 mode, pulled the most amps and fit the pill perfect so I used that one. I have been unable to log in and order more since I got that one because LCKLED is doing maintenance on there site. I had ordered a similar 3 mode one from KD but it's came as a five mode and the others have a different micro controller didn't fit or don't pull enough amps or are 5 mode.
And the only other one is in Las Vegas. I'm trying to feel bad about it. (I promise)
Foy
Your light got here first so you got it, others will have to wait. Kumabear got another awesome driver a different one but also with thermal management and low voltage warning for his Skyray Triple X, he is also super happy.
(laughing)
I would be too.
I swear, almost every light I get from IO is under driven. I just got the TC6 today. They give you a choice of 2.5 amps (black) or 2 amps. (grey) Mine pulls .90 so, with 2 x 18650 that 1.80?
I still really like it but it ain't 2.5 amps. Drew even less with protected cells.
myskyraysucksFoy
As promised; here are some beam shot comparisons. All I have to compare is the beam shot I took 3-11-12. They are not positioned/aimed exactly the same but I think the difference is rather obvious.
Beam shot taken 3-11-12 with original 2.30 amp driver. (2 x King Kong 26650) Taken with my old Canon Power Shot SX20 IS, 1/4 second @ f2.8.
Beam shot taken tonight (4-14-12) with 2.80 amp driver. Taken with my new Canon Power Shot SX40 HS, 1/4 second @ f2.7.
Old driver on the left, new on the right.
I'm sorry about all the variables. Maybe I need to do it again using my old camera. Apparently, my new camera has a wider begining zoom. I swear that placement is within a few inches of each other, I just had the tripod set a little higher. These look so different I had to go back and make sure the old beam shot really was the JM05. Why did the beam pattern change so much?
Bottom line; it is one hell of a lot brighter.
brighterFoy
If it's the driver I'm thinking of, he should be - it costs more than quite a few single lights around here....
Thanks Foy. It is a bit odd about the beam pattern changing though. Has Foy developed the ability to change light rays? Scary. Can you fit protected 18650 batteries in your tourch and do the end cap up fully?
I don't have any protected 26650s but two protected Solarforce 18650s (with the sleeves) are a snug fit. It feels like I might break something if I tighten it all the way.
Are my pictures showing up for everybody?
Foy
Pictures are showing up extremely bright here.
They look perfect on my machine.
justcuriousFoy
