Okay, I finally got these. Not bad at all. They’re crapping velcro and elastic all over the place, so they’re really adjustable, even the length of the flap! “Universal” is right. The only drawback is sheer bulk.
Lens-down, the bottom “cup” is a bit too tapered, so the light won’t slide down all the way, but lens-up, it bottoms out nicely. Like I said, even the flap-length is adjustable, just wedge your finger in the hole to separate the velcro, then slide the flap longer/shorter as you’d want it, then squeeze it together again. No belt-loop, but 2 velcro(!!) molle-type straps so you can attach it to a bag or whatnot. There’s also a hangy-loop up-top for maybe a D-ring or carabiner if you want, too.
And the ’30 fits into it (lens-up) with the switch and usb port almost perfectly above the edge of the material, as if made for it. Not bad at all.
I think I’ll still keep my SP32A on my bag, as it’s lower-profile and not nearly as bulky, but damn, if I wanted to, now I can hang my ’30 on it, too or instead.
And it’s got that Wiseau thing going on, too. Gotta love it…
Hey, for <4bux a pop, go for it.
