Aw, you shouldnāt have posted the bill, we trust you to the very end. Needless to say a reward for you should be granted admittedly. Iām really really thankful you make rare (hard to obtain where I live) leds available for us.
There are some Varta hosts for multiple LEDs (up to 7). From the technical data I assume current is well within the specs, i.e. <=25mA. Those Vartas are not bad qualitywise, but I have not tried to open them. Yet.
Sounds potentially handy. Is this one you built, or is it available as a finished product or kit somewhere?
Hopefully, but we donāt know for sure, much less when it might happen: Sofirn C01 host version
If you havenāt put a Yuji in a coin cell light like the Photon Freedom, itās almost a must have, and it looks like this LED would also be a great choice. Maglite Mini incans are also very easy to put a 5mm LED in.
If you want to get really fancy, I believe you can send McGizmo an LED of your choice to install in a McGizmo Sapphire, although perhaps he still has some Yujiās left.
If you want something in the middle, there is a Surefire A2 mod product that may or may not still be available called an āonion ringā that a CPF member makes. It holds 3 LEDās and has a potentiometer to adjust output.
And then, of course, 9x LED lights are easy to come by. They can usually be disassembled by removing the batteries and pressing the pill out of the front of the light.
A mix of the 3400K and 5600K in a multi-emitter light might be interesting. If theyāre in equal numbers, the average CCT would be 4500K, which is a nice neutral. If itās like other LEDs that have been used this way by some BLF members, it would actually turn out looking nicer than using the same number of just 4500K emitters in the same light.
Oh okay nice! Iād be interested in 25 3400k and 25 5600k if ever you plan on getting the 5600k and if I can do that(I donāt want to mess up your inventory since you only ship 50 per pack). As DavidEF suggested I just plan on mixing these for a neutral temp.
The reason that I didnāt plan to go for 5600k is that Yuji still sells 5600k 5mm (and I believe there are still some of these or similar clones selling in the wild). I donāt plan to step on their toes (yet). But if enough people want me to do it, then I will do it, no objections But maybe I will, after the 2nd batch.
