Test/review of Vapcell NCR18650 3400mAh M34 (Blue) 2019
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 weeks 12 hours ago
DSC_9288
Official specifications:
  • Model: NCR18650 3400mah 10A
  • Size: 18.3*65.3mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Typical Capacity: 3400mAh (0.2C discharge)
  • Min capacity: 3300mAh (0.2C discharge)
  • Weight: Max: 49g
  • Internal resistance: Max: 25mOhm AC 1kHz
  • Standard Charge: 1000mA, CCCV 100mA cut-off
  • Quick Charge Current: 2000mA
  • Max Continuous Discharge Current: 10A
Vapcell%20NCR18650%203400mAh%20M34%20(Blue)%202019-info
A high capacity 18650 cell that can deliver a fair amount of current.
DSC_9285 DSC_9286
DSC_9289 DSC_9290
DSC_9291
DSC_9292
DSC_9293
Vapcell%20NCR18650%203400mAh%20M34%20(Blue)%202019-Capacity
The two batteries matches very well.
Vapcell%20NCR18650%203400mAh%20M34%20(Blue)%202019-Temp-7.0
Vapcell%20NCR18650%203400mAh%20M34%20(Blue)%202019-Temp-10.0
Vapcell%20NCR18650%203400mAh%20M34%20(Blue)%202019-Temp-15.0
The batteries gets too hot at 15A.
Vapcell%20NCR18650%203400mAh%20M34%20(Blue)%202019-CapacityTimeHours
Vapcell%20NCR18650%203400mAh%20M34%20(Blue)%202019-Energy
Vapcell%20NCR18650%203400mAh%20M34%20(Blue)%202019-PowerLoadTime
Vapcell%20NCR18650%203400mAh%20M34%20(Blue)%202019-TripCurrent
Vapcell%20NCR18650%203400mAh%20M34%20(Blue)%202019-Charge
Vapcell%20NCR18650%203400mAh%20M34%20%28Blue%29%202019-Pulse-1A-10-10-2.5V-IR
Conclusion
This looks to be a good high capacity cell.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
ggf31416
Last seen: 5 hours 34 min ago
That’s interesting. Curves similar to the LG MJ1, yet slightly better most of the times, slightly worse than the NCR18650GA, most likely a tradeoff for improved cycle life. If Vapcell hadn’t told us already that it is “Tesla Panasonic NCR18650BG rewrapped” I would be at loss.
Superstocker
Superstocker's picture
Last seen: 15 hours 51 min ago
Thanks HKJ!
vapcell Dennis
vapcell Dennis's picture
Last seen: 1 hour 37 min ago
Thanks HKJ test the battery Thumbs Up
vapcell Dennis
Yeah 。, it is Tesla Panasonic NCR18650BG rewrapped Smile
Price is very cheaper than GA or 18650B
