I’m looking for some info on the MF01S, probably mentioned somewhere but I’m unable to find it — what driver, eg. FET + 5? FET + 5 + 1?
On battery insertion, the flashlight is in regulated NoPWM mode — around how much current (7135 x ??) is it consuming in this mode, and also around how many lumens (I suppose around 700 lumens regulated level, on battery insertion, for the neutral/cool-white 18x SST20).
I am a little confused about how the Auxiliary LEDs are supposed to function. If I turn the first dial so that the green LEDs get brighter the blue and purple ones go OFF. With that dial set to green being bright none of the other have any effect.
Is there only a set amount of current going to ALL of the emitters that is being divided up between them, and my only choice is how much goes to which LEDs? Or am I just doing it wrong? I would like to see all of the color LEDs be maxed out like the green ones are when only those are on.
I ordered an MF01S but I’m not sure what batteries to buy. There seems to be conflicting information about whether it takes button top or flats. Can someone recommend a battery?
I’m thinking Samsung 30Q button tops.
You can technically use flat tops but it can stretch / tear the the 18650 wrapper and insulator from what I’ve seen online. If you already have suitable flat tops and a good soldering iron, solder blobs will work well too.
Just saw your comment about looking for non-PWM drivers. I’m not that familiar with drivers, but I generally test if each flashlight has PWM (my method is a bit crude — I shine the light through a small portable fan blades). I’m not sure how fast the fan blades spin, but for BLF A6 driver or Biscotti or Bistro or NarsilM or Anduril, I can still “see” the fast PWM pattern on lower brightness levels, using this method.
However on some flashlights I tested, I couldn’t “see” PWM, so I determine they have No PWM (or are faster than what I can observe by shining flashlight thru the spinning fan blade).
These are some flashlights I tested using my crude method above, and I can’t “see” PWM on all their brightness levels (lowest, medium to high levels):
I got my MF01S today, awesome light. Anyone have tips for attaching the lanyard that came with it? Doesn’t seem that it should be that hard but I can’t get the ends to fit through the holes going from the inside out. I can get them through going from the outside in, but doing it that way would prevent it from tailstanding…
Also, this light is supposed to be red, and it is pink. Disappointed in the color.
