Not sure how good those meters below $50 will work, but here's what I've been using (about $180).
I've been using a Reed Instruments SD-1128SD (Amazon link) for all my runtime graphs. You can view my runtime graphs by clicking on my J5 or SC700d reviews in my signature. It meets all your requirements (except price) - although it has an RS232 connector for hooking up to a computer and would require a USB/RS232 adapter (I've never used or needed that function). Runtime data is copied to an SD card that you simply pull out and plug into your computer for the basic Excel file. Uses six AA batteries, which I've found gives about 3-4 days of runtime on Eneloops, but I also use the optional wall adapter for long tests.
If you order one of those Aliexpress meters, I would like to know how well they work.
This might be a good option, except for the price ;) But I might just get it... the smartphone is hopeless.
Tonight another problem. After waiting 3 hours, I noticed the Ceilingbounce app already stopped after 2 hours :(
My phone probably just turned the app off or something, but this is annoying. I need to log longer runtimes as well.
I have had the same issue with the Android app I use, but it’s just a quick trip over to the Doze settings (or your OEM equivalent) to make sure it doesn’t happen.
App info > Battery > Battery optimisation on stock Android Q.
Finally got myself a second hand Extech HD450 for my runtime graphs. It's not perfect at all, but it will do the job..... I hope..
We'll see how cumbersome this is. It uses a USB Mini (not micro) to connect to a PC. You can either use it as a standalone meter, or connected the the PC. I tried it, connected to the PC, and it seems to be doing the job.... except for the data output.. it adds timestaps like: 2019-09-25 22:10:05. so need to figure out how to make that into clear data... starting from 0 minutes. Instead of the hours of the day.
How about the UI/UX? ughhhh the buttons you have to push and the settings you have to set.. just don't make sense at all.... so completely useless. I prefered having a few extra buttons just to manage these things. A clear Start recording and Stop recording would have helped as well. Can't understand these companies make so horrible UIs.
M. one can also use smartphone as luxmeter logger. there are apps on playstore. they save the data in a common format (csv or similar) and one can postprocess it on the PC or laptop.
Converting a time stamp hh:mm:ss to a counter starting from 0sec is a common task ,
smartphones have brightness sensors. the light meter is an android app. there are plenty of them called 'light meter' or 'lux meter' on google playstore.
smartphone won't die if it's connected to USB charging (powerbank or wall charger).
I've tried it, works well, convenient "UI" and file management. but sure, a physical light meter is the more robust alternative.
Sorry, I meant a light sensor. I also used the Light Meter app with my phone, but needed it to receive calls and messages. A second phone would be as expensive as a second hand /new lux data logger, but with extended battery life.
I could never figure that out either. So . . . . .
In my Reed Instruments, I always zero the hours/minutes/seconds just before I start a runtime graph. I have to do this every time I do a runtime, but it only takes seconds once you figure it out. Excel then accepts this as starting at 12:00am.
The Benetech GM1020 is ok if you master installing the driver (the device apparently uses a fake FTDI chip and needs an old driver) and upload the settings (doing this the first time is tricky). Beware: Windows 10 eliminates your driver in more recent versions, so it has to be reinstalled from time to time. And it’s getting harder each time.
Last time I did this I had to deinstall the Win driver and install the old driver before Windows could find the new, non-working one. Disconnecting from the net might work, too.
I can help if anyone wants to take this route. The GM1020 is the only budget meter able to store that many data points.
Good call Terry, that is a great idea. This is one of the things they could have improved, but on the other hand, most people probably use it for something else, and not for runtime graphs :)
I could find a driver and software online for the Extech, so I think I'm okay.. not sure if something could cause troubles in the future of course.
Thanks Unheard, thanks for sharing. If anybody goes that route, they know what to do.
Note that the Reed Instruments does NOT have to be tethered to a computer. It has a memory card slot - that I remove when done with runtime tests. It also has an optional external power supply that can keep the data logging going for days if necessary (see sample below). I don't think the Extech has either. I wonder how long the Extech can run on one 9V battery? The Reed Instruments uses six AA's.
Although I already have 2 log meters, 1 being less than ideal and including some problems (Extech HD400) the SDL400 does a good job at what I want it to do.
But for the sake of other reviewers, a little bump to see if there are any other alternatives.
-Completely useless because the drivers are impossible to install on anything running windows 7 or newer.
-After installing the drivers on a W10 machine running a virtual instance of windows XP it works great and can easily export values to excel, you can set minimum/maximum value for start/stop, customize data logging interval and real time monitoring. When I was doing reviews I set up a macro to automatically export the values to my runtime graph on excel and after some quick value touch ups I would have a nice runtime graph in less than 5 minutes.
Downsides are it uses a proprietary port so the meter dies with the cable, and it won’t receive power from USB meaning it will drain your batteries QUICK unless you buy one of those Li-Ion to 9V adapter with usb charging from eBay.
Once past the initial setup it is a breeze to use and export the values to your runtime chart. I’d recommend buying one and try to get the drivers sorted out, worst case scenario you get a light meter with no data log function I contacted UT asking them to update the drivers (they just need to sign them) but received no response.
