Thanks for the advice! I’m going to head to the hardware store tomorrow and pick up some new, curvier PVC tubing and have a go at building a new one. I’ve also ordered some light diffuser sheets from eBay which I’ll add along the light path too.
How would you design the light “input” end? I’ve seen some people use foam as well.
At least I have calibrated lights now! Watch this space…
It’s definitely tricky. You want an opening sized just right. Both my TA Tube and JoshK Sphere have large openings with 4 or 5 adapters that have different inner diameter holes. This seems to work well. It also allows you to move the flashlight head in and out of the opening.
I’d like to have a big 6” adjustable aperture that was chrome plated on one side.
I don’t think they are made that big, though. Probably really expensive if they were available.
OK so a quick redesign of my tube to make it bendier, and I have the following multiplication factors. There’s two sheets of diffuser in the middle.
BLF 348: 0.113
S2+: 0.126
With these multipliers, it gives the following results which are all too low. All are full power / turbo on freshly charged high current batteries. I’m pointing the light just inside the entrance and using the white cutout to close the hole a bit.
It seems that your setup is biased towards cool (or low CRI) or throwy since the factor is much higher on the S2+. Also this would explains why the wide floody beam of the optics in the Emisars read low.
Did you use the average of those two correction factors for calculation. The S2+ factor would be more pertinent to the Olight M2R calculation. That one doesn’t seem too far off.
With the S2+ as the calibration reference, the M2R would read 1537 lm which would be pretty much bang on. I measured it at 1500 lumens which is what Olight also specifies it at. The X7R is much floodier, which explains part of the error, but my sample wasn’t near 12000 lumens either.
Wow, thanks for sharing this
My recently built lumen tube was reading almost the same numbers with a S2+ XPL HI-4B with 8*7135
I thought it was reading a bit low, but for other lights with given numbers, all my measurements weren’t to far off. It seems my setup is better than i thought !
I have tweaked the setup, this was the initial build
I’m pretty sure his LX1330B lux meter is a bit more sensitive to cool white than it is to warm white (same for HS1010A). If your testing a cool white light, use the 0.126 factor and if measuring a warm white use the 0.113 factor. If the light is neutral white, use a factor like 0.120.
Most of my lights are CW with a few NW, so I set my lumen tube for CW readings. If I do measure a NW light I try to remember to add a little more to compensate. I forget the correct number, but something like 3 percent. WW might read 5-6 percent low.
That certainly looks better. You say you put two sheets of diffuser material in the middle? They are probably acting like a single sheet. It would probably be better to spread them out. That way you have partially diffused light coming from the first one and then hitting the 2nd sheet to further diffuse it.
I am trying to find out what others have measured the x7r turbo at. 31% below spec seems pretty big, but might be accurate. Manufacturers often over rate their products output, but I thought olight would be a bit closer than this.
Okay, it seems Maukka has tested the x7r. It was tricky for him to measure because the proximity sensor would reduce output. He measured 3 lower levels in his sphere, then measured all levels outside the sphere, I’m guessing like a ceiling bounce. Then he matched up the 3 lower levels and calculated the upper levels. He also says the 12,000 lumen rating from Olight is at Turn On, not 30 seconds. :disappointed:
Maukkas Turbo S measurements at 30 seconds were 9,700 lumen. Your still reading about 14% lower than him. Maybe the proximity sensor is reducing output? IDK.
I asked him about this as well. He has different lights. His S2+ is using an SST-20 in 4000K and the blf 348 has a 219C in 5000K. So they are much closer in cri and color temperature than Maukka’s earlier lights. This explains why they both read so closely to spec.
Since your setup for high cri and NW, I would say your reading the lower end of the spectrum and are fine for WW and NW. If you measure low cri CW I would subtract about 5%. I think this is the number we found using the HS1010A like you have.
OK, I just ordered lights. Thank You “maukka” for your hard work and dedication providing us with these Calibration Lights.
Now I need a suggestion on plans to build a lumen tube.
