It should work now.
Thanks it’s working…
The server is up but the store is not accessible.
It's back now, but until some updates are done I'm not sure how long it will work (again), so if you plan to order, it's good to do it now.
After some updates web is working stable now.
Luxeon MZ (on all PCBs), Osram IR and Luxeon IR are on clearance sale:
https://led4power.com/product-category/leds1/lumiledsluxeon/luxeon-mz-4x2mm2-die/
https://led4power.com/?s=4715as+osram&post_type=product
Hi Neven, your lighted switch boards are 16.5mm in diameter. Can I sand 0.5mm off to make it fit in a Convoy T1?
Yes.
What’s the maximum I can safely shave off?
Switch pad that's connected to central pad/spring is closest to edge, so that's the limit.
I was able to get some additional CULNM1.TG LEDs, but not much, listings are updated.
Thanks
Any news about new drivers?
And now on a Q8 board as well
Any news on the Boost HX ?
There was listing for 4xCULNM1.TG before, maybe you've missed it because it was on second page.
No news regarding HX.
In development.
Can you change the software in ld-b4? 10 clicks to enter the configuration menu is not enough for me. Very often I accidentally enter this. Can you increase the number of these clicks? for example up to 20?
You can try to enable password for time being. I have had this problem but only right after building light where I am testing everything. In normal use I dont bother to enable password cause I find I dont run into the problem unless I am quickly running through testing and scenarios.
Password enable should be good enough.
Chatika vas Paus, do you get there cause you “miss” your mode and have to cycle back around? If so, maybe we ask for Bistro-like “long press” to reverse
A little bit of it. Sometimes. And I love bistroHD just among other things for long press to previous mode.
But…
I mean, I put this driver in Convoy BD06. There is a switch on the side. The thread on the tail is without anodization. When I insert the battery after charging back into the flashlight, I sometimes have the switch pressed, flashlight is turned on, but I don’t know that. Then the flashlight starts flashing when screwing the tail and thus activates this menu.
