[1900k edition is in!] WTS: 1900k-5800k 5mm LED 95+ CRI
531 posts / 0 new
contactcr
Last seen: 8 hours 32 min ago
Re-posting this old Yuji mod just for ideas:
My first LED swap which didn’t require solder. In fact I only used a screwdriver, wire cutters, and tweezers:
I recently ordered some batteries from Shockli’s aliexpress store and they threw in some freebies with my order. One was this cheapo keychain light. It has a 5mm straw hat LED that is press to activate and has a tiny switch to “lock” it on.
I bent and trimmed the legs of my Yuji 95 CRI 3200K LED
We have light!
I just now am realizing it had 2 stacked CR2016 batteries so I am probably giving this thing way too much voltage? Maybe a 2032 battery would have been more appropriate, who knows. I guess if it dies i’m out 55 cents..
slowtechstef
slowtechstef's picture
Last seen: 1 year 8 months ago
If you still have stock I woukd be interested in 1 pack as well. See the PM.
DavidEF
DavidEF's picture
Last seen: 6 months 10 hours ago
We have light!
The CR2016 cells are 1.5V nominal, so two of them would be 3V, which is fine for a white LED.
- The YKK Philosophy
contactcr
I dont know anything about the cells but when I look at replacement ones on Amazon it says 3V nominal
DavidEF
DavidEF's picture
Huh. Yeah. I just looked. You’re right. Hmm. Curious thing.
Kame Sennin
Kame Sennin's picture
Last seen: 2 years 1 month ago
contactcr wrote:
I just now am realizing it had 2 stacked CR2016 batteries so I am probably giving this thing way too much voltage? Maybe a 2032 battery would have been more appropriate, who knows. I guess if it dies i'm out 55 cents..
I have used and gifted dozens of these small lights, all the white ones use 2xCR2016 and i have never seen a single one with a fried led.
These coin batteries have a high internal resistance so the voltage drops when you load them with a led.
Barkuti
Barkuti's picture
Last seen: 4 hours 59 min ago
DavidEF wrote:
Huh. Yeah. I just looked. You're right. Hmm. Curious thing.
CR2016 cells are “3V”, but their internal resistance is very high. Thus, 2x in series CR2016 cells drive a 5mm led well.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases! They are better called exosomes, and they are cell cleaners! Watch Virus Theory vs Exosome Theory video and awaken to this truth! Check this article by MD Andrew Kaufman. Read the book “Béchamp or Pasteur” by Ethel Hume for in-depth information.
rngwn
rngwn's picture
Last seen: 2 weeks 5 days ago
That and the fact that you don’t turn that on for a sustained period. Even if you overdrive these LEDs and degrade them way faster than their rated lifespan, you probably won’t notice it.
iamlucky13
Last seen: 8 hours 33 min ago
CR2016 cells are indeed 3V. The “CR” code denotes a lithium manganese dioxide chemistry, nominally 3V.
Alkaline button cells are 1.5V and are given “LR” code. The typical form factor is also fatter and taller than lithium coin cells.
A pair of CR2016 cells shouldn’t be any concern, but because of the low forward voltage on the Yuji’s, they run pretty well on a single CR2032 cell, in my experience.
I haven’t done a controlled test, but I’d expect you would get more stable output and significantly longer runtime out of a single CR2032 compared to a pair of CR2016’s, although you might get higher initial output out of the latter. The massive voltage drop the pair of smaller batteries experience is in part due to a lot of energy being wasted on internal resistance.
Either cell does better at these kinds of loads with intermittent use (a few minutes at a time) than continuous use. It’s surprising how much the voltage recovers when a load was removed in a test HKJ did:
http://budgetlightforum.com/node/66184#CR2032,_Panasonic
rngwn
rngwn's picture
Shipped
slowtechstef: RR146459731TH
Noctiluco: RR278756610TH
mitsuki08: RO247700037TH
Unheard
Unheard's picture
Last seen: 6 hours 24 min ago
Thank you so much, rngwn!!! Thumbs Up Beer
Smile, you cannot kill them all.
khas
Last seen: 1 week 10 hours ago
Mine arrived in Denmark today.
My wife have some tee-lights she bought in Ikea :
The tint in the original on the left is perhaps more candle like, but it also has a hint of green. I like the “upgraded one on the right better.
Thanks again for making these available.
staticx57
Last seen: 13 hours 55 min ago
LEDs arrived today, thanks!
Tixx
Last seen: 2 weeks 1 day ago
Got mine yesterday! Thank you!
slowtechstef
rngwn, thanks for making these LEDS in good bins available in small quantities for the BLF community Thumbs Up
In my experience replacing a stock 5mm LED with a warm-white high-cri one can turn almost any shit flashlight into a hit flashlight. Well at least in my humble opinion Wink
slowtechstef
Action Halloween projector, 0.69 Euro
Kudos to iamlucky13 for the suggestion of using 2AA direct drive for a 5mm Yuji.
No PWM, no standby drain, no soldering required for 5mm LED swap Thumbs Up
Current somewhere around 25mA with 2 “newish” 1.5V alkaline AAs.
Mod with Yuji 3200K LED.
Q.E.D.
shirnask
shirnask's picture
Last seen: 16 min 52 sec ago
Mine arrived today, thanks!
djozz
djozz's picture
I did a voltage and output test on one of these 3400K 95CRI leds, and it does not disappoint, output is better than the Yuji, voltage is lower, and it can handle more current. The max is about 22 lumen at 100mA, going higher up to 120mA gets you a bit more light for a moment but it settles back to 22 lumen again within a couple of seconds. My test rig for 5mm leds is not great, the current can not be set very well and the graph shows it, but the output numbers are correct. I also re-tested a 3200K Yuji for direct comparison. This new tested Yuji has about 1 lumen less maximum output as the one I tested before, but apart from that the voltage and output curves are pretty much the same.
Also I have been running one of the 3400K 95CRI rngwn leds all day at 100mA, and it does not seem to bother the led much, output does not degrade, steady at 22 lumen. It is not quite a 50,000 hour test but it does tell something.
Edit: there seems an effect on tint though. I should do another test for confirmation but the led seemed more yellow and when I measured it again, the duv, that was -0.0038, after 12 hours at 100mA it went to -0.0007. CRI is invariably good.
Here is the tint data at 50mA, I also measured at 5mA and that is a bit better even but only marginally
I also measured tint in the warm edge of the beam, CRI is the same but in 2800K. The CCT has some variation apparently, the first led last week measured 3320K, and now 2 leds measure both at 3200K.
(the bottom leds are two of the 3400K 95CRI leds from rngwn, top left is a Nichia GS, top right are a cold and warm Yuji)
Phlogiston
Phlogiston's picture
Last seen: 4 months 2 days ago
My LEDs have arrived – thanks, rngwn!
Now I’ve seen those test results, I’m really glad I bought some Smile Thanks for the testing work, djozz!
iamlucky13
Thanks for making measurements for us djozz. I’m impressed how well this LED performs – not only more output and able to be driven a little harder, but also a lower forward voltage than the Yuji’s. Taken together, that means 20% better luminous efficacy, which would be great in lights that use boost circuits like the C01.
And very similar color. I looked up your spectrometer test of the Yuji’s for comparison:
http://budgetlightforum.com/comment/1407770#comment-1407770
I took the liberty of summarizing your two samples:
Yuji 3200K rngwn 3400K Yuji 5600K rngwn 5800K
CCT 3162 3237K 5390K (2) 5666K
Duv -0.0037 -0.0038 -0.0004 0.0010
CRI 96 96 95 98
R9 84 84 94 93
Output, 20mA 6 lm 7 lm 7.5 lm 9 lm
Vf, 20mA ~2.9V ~2.8V ~2.8 V ~2.9V
Peak Output ~14.5 lm 22 lm 22 lm 25 lm
Peak Output If 80mA 100mA 90mA 120mA
Peak Output Vf 3.6V 3.3V 3.25V 3.45V
(1) Yuji color tested at 20mA? rngwn sample tested at 50mA
(2) Maukka C01 average of 2 samples
* Edit – added Duv.
Phosphor22
Last seen: 2 years 4 months ago
Thanks rngwn for finding these and setting up the thread to sell them.
Great to see this test results Djozz. This LED looks like a fine replacement for the Yuji.
Unheard
Unheard's picture
The Yuji color is very special, probably second to none. Still rngwns LED is much more useful imo. Very bright in contrast with an evenly distributed beam (beamshot added in posting #102). Really nice. In the Fenix E01, it clearly outperforms the C01, but maybe the Fenix has a higher current driver.
iamlucky13
unheard, nice work making your E01 much friendlier. It’s the perfect form factor for this time type of emitter.
(edit – corrected typo)
Enjoy casting silhouettes on the wall in warm, high CRI!
Noctiluco
Noctiluco's picture
Last seen: 11 hours 26 min ago
Interested from Spain in two packs , send a PM
Unheard
Unheard's picture
iamlucky13 wrote:
unheard, nice work making your E01 much friendlier. It’s the perfect form factor for this time of emitter.
Thank you Smile . Yes, the bluish light had to go.
AguassissiM
AguassissiM's picture
Last seen: 14 hours 47 min ago
Thank you @rngwn . Thumbs Up
Got my package today, just in time for my new idea…. Facepalm
***Rofis MR70*TurnRaise*Catapult V6*BLF Q8*BLF Mini*BLF Micro*Haikelite MT09R* Convoy C8*BLF D80v2 SST40*MatemincoX6S*AstroluxFT03-xhp50.2*AstroluxFT03-sst40*BLF-LT1*AstroluxFT03S-SBT90.2***
Noctiluco
Noctiluco's picture
Thanks, rngwn, it would be almost impossible to have 5 mm LEDs with high CRI if it were not for your offer, greetings
mitsuki08
Last seen: 8 hours 22 min ago
@rngwn please see PM. Thanks!
rngwn
rngwn's picture
^ Shipped, tracking in #101
e1000
Last seen: 11 min 19 sec ago
got my LED’s thanks rngwn!
