No clear anodized yet. Just Raw 7075. I plan just to keep these few Raw. Will provide some clear anodized in the next run instead.
Thank you for the support!
Vinh when is the next run? I really like the silver look but want it anodized.
Run 2 is back to back.
Hey Vinh, if nobody told you yet, we are very glad you’re here, and look forward to your creations.
I think the admin told me that. You might be the second person? ahahah CHEERS!!!
Nice. Lily looks very obedient and disciplined. Just like my Husky/Shepherd!
So it is also Lizardproof
Hey Wolfdog. Long time no see.
What kind of a lizard is that?
Bearded Dragon?
Could be the title of your future memoirs:
“A Lady, a Lizard, and Lots of Lights”.
any pictures, shots of 5400 W2 LED please?.
thanks.
Looks amazing sir!
I will grab a picture next time I build one. Its pretty much just a large hot spot with a pure white tint. No hint of anything else.
Thanks
A loosen clicky retaining ring can give poor or no connection. In SLN I soldered the clicky to the copper retaining ring and this solves potential connection issue of a loosen ring. The copper retainer ring pressure now is mostly to hold the rubber boot tight against the tail cap wall for water resistant. A very loosen ring may let in water but it will no longer give connection issues as spring pressure from the light engine and the switch will always close the battery current path.
12LED MCPCB has arrived!
Custom copper shell has not so I am using our normal Quad shell for demo.
12 XPL 5000K V6 Bin is going to be AMAZING!
Ultra smooth gold plated surface for excellent thermal epoxy or solder bonding
Extra thick 2mm MCPCB VS conventional 1.6mm thick MCPCB
Left out all most + and - signs to keep elegance
4 SL logo for symmetry
Question: Should I leave the prints in Black or go with a different color?
