According to the seller this is NIOBIUM TITANIUM ALLOY. I’m assuming the orange part is copper and not cupronickel.
Wiki says there is a couple different varieties - Superconductor material classes include chemical elements (e.g. mercury or lead), alloys (such as niobium-titanium, germanium-niobium, and niobium nitride), ceramics (YBCO and magnesium diboride), superconducting pnictides (like fluorine-doped LaOFeAs) or organic superconductors (fullerenes and carbon nanotubes; though perhaps these examples should be included among the chemical elements, as they are composed entirely of carbon).
Whilst that is true, I also don’t like admitting it to myself
I made some holes in the pill in order to use tweezers to screw it in/out. The holes line up with the mosled holes.
Purrday colours
Threaded and test fit
The retaining bezel protrudes a little more than I was planning due to the not being able to machine threads for the pill right the way up to the shelf/step. I should be able to easily rectify this by cutting off 1-2 threads off the pill
I’ve stalled for a bit trying to think about how to proceed from where I’m at with this build.
I bored out the body but didn’t go right through. I tried to stop around where the tail starts.
I then flipped it in the chuck and bored the tail to suit a rubber boot
Cut off the tail section
The inside of the body looks cool Pity it won’t be seen, there will be a sleeve.
The sleeve, to help extend the length a little. Made from a solid bar of ti. The wall thickness is just under 0.5mm and may require a final pass to open the inside a fraction more once it’s fitted to the body.
I have had a hafco AL-320G for about 5 years i got it to make stainless parts for a brewery I was building. As usual it got out of control then i slowed up on the drink and went back to led grow lights herb garden at first. a “mate” dumped 20 dope plants on me after a blue with his missus and never came back for them. I took the strongest one and put it in the herb garden. That then got out of control with full digitially controlled grow rooms. I was just about to set it up so i could hit it with a frost just before harvest. The day before i planned on starting the build of an ammonia heat pump. The police pulled me up. i had all these leds and nothing to do with them. So i put a 100w into a 6 D cell maglite i had, thought i could make one of those and that put me on another slippery slope. Saving now for a new optimum lathe mill combo it would look good in my dining room with the welder.
Haha dont live on the edge jump off, my apologies for going of topic
The AL-320G is a nice machine. I currently have the next model down from that one. I also looked at the optima combo because I thought I could save on space but didn’t opt for it for a couple of reasons. The work table is limited compared to a regular mill, plus it’s not designed to do 4th axis work. Didn’t really seem worth it at the time. If I had the time and money I would consider getting one and doing severe modifications to make it a 4th axis capable machine. Probably beyond my abilities though
Main reason for a new lathe is an enclosed gearbox, also thinking about the combo so when i work out what i dont need i can buy a bigger table and mount the mill head on it. I already have indexing head, swivel/tilt vice and a heap of cutters. Haha I cant work out if im on the wagon or have fallen off it. As DB custom said it is good fun.
I came up with an idea to save space with the switch. I’ll epoxy the board into the retaining ring.
I thought I was on track to get everything to fit
…but the threads on the sleeve I made take up too much space. It’ll need to be trimmed
Luckily I hadn’t worked on it yet because I had this oveready pocket clip show up in the mail. I have 1-2 bolt on style clips but didn’t really want to be screwing tiny bolts possibly into soft copper. This clip does not fit over the threads on the sleeve so I’ll re-machine the threaded section both shorter length and narrower diameter.
To long, to short, its hard to please some people.
Looking good pp. Its amazing how some problems have to get sorted on the run and how they do get sorted. On the home run now.
Maybe I picked up wrong but you said you were going to epoxy the switch into the retaining ring?
I meant the screwed switch module would be better with a retaining ring of some sort.
I’ve found the L4P drivers & switches like a good solid ground connection.
