On your list LiitoKala Lii-40A 21700 4000mah is the best. Off your list Molicel INR21700-P42A is probably the best followed by Samsung 40T and Sony US21700TC6A. I’m guessing that this will be a 15 amp turbo draw.
Thanks for your reply, I was just about to order the Gosili’s. I’m in Australia so shipping of batteries is such a pain, very jealous of you guys in the states. That’s why I just thought I’d go with whatever BG is offering, they seem to have a knack of getting cells into Australia no problems.
Quick question: why do you think it will only draw about 15 amps? Won’t 4 leds getting driven hard be closer to 20 amps or more?
Cree charts say the XP-L HI V3 does 1094 lumen at 3 amps. 1094 x 4 = close to 4500 factory claimed for this quad. That’s 12 amps add 3 for a cushion and I’ll call it 15 amps.
I have the PL47 Gen 1, and I can confirm that it does do 2500 lumens، although it does thermal throttle quite quickly, so after 30 seconds, you are not left with much output.
I think using high drain cell 20amp above probably won’t cause any harm. If you do worried, selectable mode available : temperature control, time control…
Further more, Anduril is dedicated with FET which mean built for direct pass and properly regulated. Am I right??
