[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
On your list LiitoKala Lii-40A 21700 4000mah is the best. Off your list Molicel INR21700-P42A is probably the best followed by Samsung 40T and Sony US21700TC6A. I’m guessing that this will be a 15 amp turbo draw.
Thanks for your reply, I was just about to order the Gosili’s. I’m in Australia so shipping of batteries is such a pain, very jealous of you guys in the states. That’s why I just thought I’d go with whatever BG is offering, they seem to have a knack of getting cells into Australia no problems.
Quick question: why do you think it will only draw about 15 amps? Won’t 4 leds getting driven hard be closer to 20 amps or more?
Cree charts say the XP-L HI V3 does 1094 lumen at 3 amps. 1094 x 4 = close to 4500 factory claimed for this quad. That’s 12 amps add 3 for a cushion and I’ll call it 15 amps.
Thanks heaps for that, super appreciate it, I’ll order a pair of the Liitokala’s :slight_smile:
Would you be so kind as to tell me what the calculation would be in the case of the sst20 4000k CRi95 2500 lumens version?
Comment that I bought a pair of Shockli 4550mah purple, which according to the review of Lygte Info are very good and the price is unbeatable:
https://s.click.aliexpress.com/e/lJJPoCI8
I have the PL47 Gen 1, and I can confirm that it does do 2500 lumens، although it does thermal throttle quite quickly, so after 30 seconds, you are not left with much output.
I saw them too, don’t ship to Australia though, like most sellers :-/
Sorry no factory charts from them. This might help Luminus SST-20-W 4000 K CRI95 color and output test
New “headlight strap” looks way better than the Gen1, I’ll buy one when coupon code comes out
I think using high drain cell 20amp above probably won’t cause any harm. If you do worried, selectable mode available : temperature control, time control…
Further more, Anduril is dedicated with FET which mean built for direct pass and properly regulated. Am I right?? :sunglasses:
Is there a code for this one?
Order!!! Fireflies PL47G2 SST20 4000K CRI95 !!! including Clip, Headstrap and Magnetic Tailcap
Interested.
Interested
Interested. Thanks.
Sent.
Ordered
Interested
Interested. Thanks .
Interested. Thanks!
