18650… that’s a little loose for a 12 gauge and a bit tight for a 16 gauge… but I bet it would fit nicely in a in a high-brass 3” 12g birdshot shot cup.
Just Saying……
Or, maybe you have a pair of large jaw vice grips or channel locks that need heat treated?
Or it’s possible the sidewalls of the battery will buckle due to the high acceleration involved, jamming the battery inside the barrel, likely damaging the barrel and potentially even creating a risk of overpressure.
I wouldn’t recommend it without taking significant precautions.
@JoshK, since I’m the kind of person that likes to be friendly to my surroundings and the general environment, here’s what I would do:
1. Discharge the cell to 0V.
2. Go outside with a bucket of water.
3. Wear two pairs of medical gloves, and a full laboratory suit.
4. Open the 18650 by removing the top cap with a dremel.
5. Proceed with the disassembly of the cell, by first putting the steel casing in the water to clean it, and then doing the rest WITH GLOVES ON. DO NOT TOUCH YOUR FACE IN, and wear a respirator if possible.
Yes, but make sure to put the casing in water so that the electrolyte(comprised of HF and other solvents) gets converted into a safer form.
So yeah, just don’t open the cell up without gloves.
Some things I discovered:
1. The cell casing and anode can easily be recycled. The casing can be melted, while the anode can be rather easily separated into graphite and copper. The cathode is another story.
2. There’s quite a bit of copper inside of a cell. With thousands of cells, this could actually get rather profitable if you were to actually recycle it.
3. If you could actually weld them shut, you could make conductive spacers.
I think this is the best answer so far. You could probably add threading for a twisty head and use the body as a AA or AAA battery carrier. I’d be partial to putting the emitted inside a small hole on the negative end and using the positive contact as a clicky switch. A LOT more work, but it will still kind’a look like an 18650.
I am planning to short it out using some of that nickel strip used to build battery packs. Any day now I should be getting my spot-welder parts, then I can give it a go.
Joshk, please be safe but can’t wait for the video. I don’t know how long a direct short takes to cause venting/explosion, but that might be an iffy time window to get out of harms way after the spot weld? Just a thought. It sounds silly to say, “be careful while intentionally causing that lithium battery fire/explosion”. Hopefully you can operate the welder from behind a shrapnel guard? I don’t have a lot of experience with lithium batteries compared to a lot of folks on this forum, but I won’t ever forget the time I accidentally placed a 25R in a metal holder with leads protruding on top of the microwave. the microwave had an all metal housing, and the sparks from where the lead fell scared the living daylights out of me as I franticly swatter the bettery off of it. Taught my stupid-self a lesson quickly.
