FW3A mod thread. Post yours!
I have to disagree. If I can’t get TK Special buttons, the rabbit button is a cool alternative.
Has anyone put XP-G3 s 4K 90 cri in this light yet —- I’m looking to do something different — I have all the stock flavors and then some —- I’m thinking may a variety of 4K emitters SST 4K / 351D 3.5K / XP-G3 4K
Thanks!
This ^ Would love to have a different button option.
Flashed an updated version of Anduril and swapped in some LH351D dogfarts into my newly arrived blue FW3A
4000k SST-20 vs 5000k LH351D, orange spill on the SST-20 from a glow gasket
Thanks for the comparison photo. That really highlights the difference in beam between those emitters.
Absolutely. The LH351Ds are extremely floody compared to the SST-20s the FW3A come stock with.
I purchased a couple used FW3As —One had a couple nicks/etc — decided to bead blast and polish it—-I had been wanting to build a Triple with a mix of LEDs—I went with a
SST 20 4K / XP-G3 4K / LH351D 3.5K combination —- tint seems to be pretty nice (on wall so far) — I compared it to another FW3A with LH351D 4Ks — seems to be slightly more Rosey and have a slight bit mor throw—won’t know anything till the night comes
Love the crenellated bezel! I want one.
Don’t those LEDs have very different forward voltages?
Yes they do —- seems to be working fine — I would imagine the higher forward voltage is regulating the others—I’m not sure
Where can I buy a spare driver?
I believe Neal will sell them, try a PM or Facebook messenger.
I’ve purchased 7 total. So easy to reflash and make it your own. I’ve Evilbayed off several lights to fund these. So far, my daily carry has proved to be waterproof and absorbed lots of drops and concrete rash. Sincere thanks to EVERYONE involved in the development of this torch. I tend to use things for long periods of time. Even with a failure, I don’t believe there is too much I couldnt fix or improvise a replacement part for.
What size trit vials fit these fancy titanium clips from Neal?
1.5x6mm
Thanks! :+1:
Did you change the anodization? Could be the lighting, but that looks to be hard anodized.
What size screws did you use for the clip?
It’s hard Titanium…
2-56 or 4-40 (depends if at first you don’t succeed) with roll/form tap not cut tap… I get thru work…
. Like these….Taps – Thread Forming – OSG HY-PRO | TiConnector
