[1900k edition is in!] WTS: 1900k-5800k 5mm LED 95+ CRI
I don’t think so. The LED in Tube is most likely driven at 150ma. Unless you find the way to cut the current in half, I don’t think think this LED will survive.
Do you ship to the UK? If so, what would be the cost of one pack of 50 shipped?
Thanks
Thank you for letting us know. Mine are on the way, we’ll see.
I’ll let you know for sure tomorrow :sunglasses:
I put one in a Tube today (sorry e1000, it was not to beat you to the mod, I had precisely one hour this weekend to do stuff in my grand workshop behind the cupboard, that hour was now and this little project fitted right in).
Tube with stock led, full battery, at 30 seconds:
109 mA, 47 lumen, 78CRI, 7300K duv –0.0152
Tube with rngwn led, full battery, at 30 seconds:
84 mA, 24 lumen, 96CRI, 3200K duv –0,0042
Bit lousy pic not doing justice to the great tint:
Yes, PM me.
No worries djozz! Now I know it’ll work!
I got them. Under UV light it has red/yellowish hue like the 5600k Yuji unlike 3200k Yuji.
Left: Yuji 3200k , Middle: rngwn 3400k, Right: Yuji 5600k
Tracking numbers:
fnksb - RR278756946TH
Skuzapo - LX054010880TH
TMaxxJJ - RO247700068TH
Elaboration - RO247700125TH
/u/LoPan12 - LX054010893TH
Your so right, I almost forgot there’s a nice Nitecore TUBE having 5mm LED.
I did the same. Noticably less light, significantly more pleasant.
Mod easier than I thought.
Nice modding.
I was hesitant to buy one of the tube knock-off worrying it will kill the LEDs. Might want to try and mod one.
Thank you! :innocent:
Nitecore Tube modded. Really happy with it! Thanks again rngwn!
Thanks for that.
Is the Tube mod straight fiorward,or is there something to be carefull about? Ordered one.
No mod that I have ever done was straightforward, there’s always something unexpected that has to be taken care of (i.e. the tiny screws were tight, I had to use a very well fitting screwdriver to not screw them up). But if you have dome some modding before and do the disassemby and assembly a bit gentle (it is tiny inside), there are no big problems.
The led leads are very short (1-2mm). I had to reposition the led because it is attached only by soldering points. Make sure it’s soldered deep enough to close the housing tight. I was holding the led in right position with one hand while the other was holding soldering iron.
As far as the screws are concerned, expect the loctite on the unloosen screws. That is probably #1 reason why it’s so difficult to unscrew for the first time.
I had a look at the position of the stock led before unsoldering it. The leads of the new led I bended sharply to the side very close to the plastic and cut off alongside the plastic. This gave enough “solder length” to attach the led just as well as stock led. I always pre-tin the leads of the led and then fuse the solder with the blob on the driver board.
Thank you gentlemen. Seems doable :+1:
