[1900k edition is in!] WTS: 1900k-5800k 5mm LED 95+ CRI
527 posts / 0 new
Gebe
Last seen: 2 days 3 hours ago
Boy, these are way too warm for me but thanks for offering them!
rngwn
rngwn's picture
Last seen: 3 days 20 hours ago
If you want 5600k and you live in the States. This guy right here has it.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk...
Unheard
Unheard's picture
Last seen: 5 hours 50 min ago
1stein wrote:
Took also a few Fasttech flagships: authentic
Got my samples. Direct driven, i.e. no electronics. The PCB can be taken out by pushing the LED. It just falls apart. Piece of cake to replace the LED, but maybe not worth it. Body must be some kind of zinc alloy.
The Mateminco BL-1 is much nicer. I ordered the copper type, and it appears to actually be made from copper! Hope I can take it apart.
Smile, you cannot kill them all.
ludolf
Last seen: 4 days 8 hours ago
Nitecore Tube would be suitable for this led?
rngwn
rngwn's picture
I don’t think so. The LED in Tube is most likely driven at 150ma. Unless you find the way to cut the current in half, I don’t think think this LED will survive.
TMaxxJJ
Last seen: 1 min 11 sec ago
Do you ship to the UK? If so, what would be the cost of one pack of 50 shipped?
Thanks
1stein
1stein's picture
Last seen: 2 hours 41 min ago
Thank you for letting us know. Mine are on the way, we’ll see.
e1000
Last seen: 22 hours 28 min ago
I’ll let you know for sure tomorrow Cool
djozz
djozz's picture
Last seen: 1 hour 49 min ago
I put one in a Tube today (sorry e1000, it was not to beat you to the mod, I had precisely one hour this weekend to do stuff in my grand workshop behind the cupboard, that hour was now and this little project fitted right in).
Tube with stock led, full battery, at 30 seconds:
109 mA, 47 lumen, 78CRI, 7300K duv -0.0152
Tube with rngwn led, full battery, at 30 seconds:
84 mA, 24 lumen, 96CRI, 3200K duv -0,0042
Bit lousy pic not doing justice to the great tint:
rngwn
rngwn's picture
TMaxxJJ wrote:
Do you ship to the UK? If so, what would be the cost of one pack of 50 shipped? Thanks
Yes, PM me.
e1000
No worries djozz! Now I know it’ll work!
flightless22
flightless22's picture
Last seen: 3 hours 30 min ago
I got them. Under UV light it has red/yellowish hue like the 5600k Yuji unlike 3200k Yuji.
Left: Yuji 3200k , Middle: rngwn 3400k, Right: Yuji 5600k
rngwn
rngwn's picture
Tracking numbers:
fnksb – RR278756946TH
Skuzapo – LX054010880TH
TMaxxJJ – RO247700068TH
Elaboration – RO247700125TH
/u/LoPan12 – LX054010893TH
1stein
1stein's picture
!{width:70%}https://i.imgur.com/B2xY3xor.jpg!
Your so right, I almost forgot there’s a nice Nitecore TUBE having 5mm LED.
I did the same. Noticably less light, significantly more pleasant.
Mod easier than I thought.
rngwn
rngwn's picture
Nice modding.
I was hesitant to buy one of the tube knock-off worrying it will kill the LEDs. Might want to try and mod one.
fnksb
fnksb's picture
Last seen: 2 weeks 2 days ago
rngwn wrote:
Tracking numbers:
Thank you! Innocent
e1000
Nitecore Tube modded. Really happy with it! Thanks again rngwn!
Gebe
Thanks for that.
Unheard
Unheard's picture
Is the Tube mod straight fiorward,or is there something to be carefull about? Ordered one.
djozz
djozz's picture
No mod that I have ever done was straightforward, there’s always something unexpected that has to be taken care of (i.e. the tiny screws were tight, I had to use a very well fitting screwdriver to not screw them up). But if you have dome some modding before and do the disassemby and assembly a bit gentle (it is tiny inside), there are no big problems.
1stein
1stein's picture
The led leads are very short (1-2mm). I had to reposition the led because it is attached only by soldering points. Make sure it’s soldered deep enough to close the housing tight. I was holding the led in right position with one hand while the other was holding soldering iron.
rngwn
rngwn's picture
As far as the screws are concerned, expect the loctite on the unloosen screws. That is probably #1 reason why it’s so difficult to unscrew for the first time.
djozz
djozz's picture
I had a look at the position of the stock led before unsoldering it. The leads of the new led I bended sharply to the side very close to the plastic and cut off alongside the plastic. This gave enough “solder length” to attach the led just as well as stock led. I always pre-tin the leads of the led and then fuse the solder with the blob on the driver board.
Unheard
Unheard's picture
Thank you gentlemen. Seems doable Thumbs Up
DavidEF
DavidEF's picture
Last seen: 6 days 7 hours ago
Here’s a question. I can’t remember if anyone asked it yet, but I think not. What would the result be if I tint mixed these high CRI, low CCT emitters with some low CRI, high CCT cheapies? For instance, if I replace five of the emitters in a cheap 9-up light with these emitters, leaving four of the stock ones, which are probably 70 CRI, 6500K CCT, what could I expect? I know the resulting CCT could be calculated easily, but I’m wondering what the resulting CRI would be. Does CRI “blend” linearly like CCT does, or not?
- The YKK Philosophy
Kame Sennin
Kame Sennin's picture
Last seen: 1 year 6 months ago
It is very likely that the 9 leds cheapies use leds with a CRI far lower than 70 (i have some at home will do the test tonight)
djozz
djozz's picture
The spectra are simply averaged, so the cyan dip may be halved, and far red too, I guess the CRI may be in the middle too.
rngwn
rngwn's picture
One thing to note here is that as far as cheapo 5mm LEDs go, you might end up having the stock LED with 10000k or colder and godawful tint. There are no minimum to the quality controls there.
Kame Sennin
I am new to the CRI things and my setup (Colormunki Photo + ArgyllCMS) might be poorly missused but from what i see on my cheap lights they range from a CCT 11000K / CRI 74 (R9 -20) for the better to something that Argyll can't even understand telling me something like 999911K / CRI -1 for most of the others.
My guess is that the blue peak is so high compared to any other color that the calculation fails
iamlucky13
Last seen: 4 hours 39 min ago
As mentioned above, intermediate CCT and CRI. Duv will be lower than either emitter, which is a benefit.
The cheapo LED’s I have tried have a higher forward voltage than the Yuji’s, which means also than these replacements. The result will be your high CRI emitters are driven harder than your low CRI emitters. It might not be enough to cause a problem though.
The cheapo LED’s are also usually a ~15 degree beam. The much tighter beam will mean major tint deviation across the beam. It might be possible to resolve by sanding the dome of the cheap LED’s.
I have mixed equally numbers of 3200K and 5600K Yuji’s with similar beam angle and forward voltage in a test, and the result was really good, around 4500K. I only tested it a limited amount, but I actually liked it slightly more than the only Nichia 219B, SW45K light that I own.
