I added you for another but that gives you 5 and not 4 since you originally requested 4 on post # 5852.
Please add me for one more, total of 3
Please put me down for one.
Thanks
Put me down for one of them puppies!
Thanks!
Así que pude hacer un progreso razonable en la traducción al francés de las instrucciones de uso de nuestro querido LT1.
Enough toying around, so while translating I gathered my remarks and questions. As it is becoming quite a list, and to keep the project crowd-written I'm sharing all that mid-translation to keep it humanly manageable. They follow the order of the manual and are all candidly made, I did not reread the last X pages of the topic where some point might have already been discussed:
- Why no reference to the forum, like a "crowd-designed lantern" mention put near the title, along the first reference to the great Anduril?
- The order in the battery brands suggestions does not look like random. I'd suggest to use alphabetical order to avoid the creation of the feeling of subjective inclinations.
- We write to use 5V USB sources in the safety precautions paragraphs, but later we say the user can go up to 15V sources. That feel inconsistent.
- Should the diffuser be described more as "textured" rather than "opaque"?
- I saw so far no words about protected or unprotected battery compatibility?
- There are multiple references to the button-top batteries, do we really need to repeat it each time?
- To ease the natural ordering of the "Quick Start" part, I'd propose to numbered the main steps. Step 1, step 2, etc
- Does anyone knows a great french translation for "electronic side switch"? I'm rather short on that one, all I that I can think of does not seem to "click".
- For disambiguation, I'd suggest to use "battery charger" instead of just "charger" (that might be mixed with USB charger).
- "70% max on ext. source" part is confusing. How the user is supposed to control/even know this figure? Shouldn't the LT1 automatically lower/control its output regarding the energy source?
- Some instructions are repeated. Like maximal dimensions of batteries (first paragraph, and again in specifications). General rule : are repetitions voluntarily made or can be "smartly" controlled?
- Is the default mode stepped or smooth? Various paragraphs states one thind and the opposite, notably specifications and UI.
- What does mean " double-click (green double lines)" ?
- Some things looks not perfectly ordered. For instance, in UI texts we speak about levels (as in level 150) before introducing what levels are and what does they represent.
- Acceleration command to leave "MOMENTARY" mode is achieved while HOLDING or with multiple CLICS ?
- Why not "for simplifying the UI for users who want a simpler experience."=> for simplifying the UI for users who wants an easier experience." or something the like?
- I'd propose that MUGGLE have an added explanation stating that it also intent to securise the usage of the LT1.
- Blinkies : are there really two different way to access them from the same OFF state? If yes, this might be confusing ( "do either a 3 clicks (3C) from OFF or a 2 clicks and, hold” (3H) from OFF")
- "3.1 volts or lower" => why not directly state "lower than 3.2" ?
- Correction Click three times, but hold the third click until the strobe mode stars.=> Click three times, but hold the third click until the strobe mode starts.
- Funny, I was today old when I realised that english-speakers are litteraly also using FAQ (foire aux questions / frequently asked questions). That fact has been hanging out in plain sight for my whole web life.
- DBSAR is credited for "design" and "contributing design info". Isn't stating the first already including the second?
- And are you generally using "design" as in aesthetics, conception or intending both meanings?
That's all for now folks !
Some interesting points, its difficult to know as i know very little French language.
And if I may, I would like to update my count to 2
I cannot promise, that I will buy all the lanterns I am interested in within a single package, but I might need 2 further units (if I can make all my units as a separate purchase).
I was already interested in 2 units. Now it is 4 unit in total.
I added the additional 2, and you are not obligated to buy them all.
IMHO, the English version of the manual is fine as it stands. No changes necessary.
Could I have one more lantern, please, for a total of 5?
Could you put me down for another one, for a total of 2? Thanks.
Two please.
a second one for me please.
So excited for these lanterns - awesome work!!
1) If purchased with the Sofirn cells - will it be able to be shipped overseas fine (I know there are issues shipping lithium batteries)?
2) Are the Sofirn cells best suited for muggles (myself included…!) or are there other cells I should buy - if so which exact ones should I buy, please? ’
I am here in the US this week so if Sofirn’s aren’t going to work out then I need to buy others here now.
Thank you!!
The Sofirn cells that you can optionally buy with the lantern seem like a good deal to me. Since they’re button tops they should work just fine.
Don’t see why there should be an issue shipping to US. Bought some Sanyo NCR18650GA with S2+ from aliexpress, they got delivered, slow but still came. But any 18650 button tops should work, you can buy from US sites they will arrive faster.
Just a photo a found of the LT1 prototype V1 where it all started, on the summit of a mountain in a remote wilderness area back in 2016, and this old, beaten, battered, original predecessor to the current BLF LT1 is still in use.
I’m not sure since I didn’t write the manual, but looking through it, I see at least three links to threads on BLF.
The only required link is the one necessary to satisfy the license. Since it uses GPLv3 code, it needs to have a prominent notice somewhere that it uses free software distributed under the terms of the GPLv3 license, and the source code is available from [link to the code]. And that legal requirement is satisfied, so the rest of the links are more of an editorial choice. I haven’t really been involved in that.
The charging circuit and driver circuit work totally independent of each other, with no awareness of what the other one is doing. The driver has no idea whether its power comes from batteries or USB.
Stepped.
The only way to exit momentary mode is by physically disconnecting power.
There are two different sets of blinky modes — blinkies (3C) and strobes (3H). It might make more sense when looking at the UI diagram.
Please put me on the list for one. THX.
