I see two totally different screws there, an allen head and a cross head - anyone know which one is production?
Looks good!
Looks good!
Yes, this is a good point. It is nice to recognize the contributions of the community who made this light possible.
All I was saying is that the legal requirements have been met, so any additional information is somewhat optional. Adding text to recognize the community is good though. It will depend on whether you can coordinate changes with the authors and translators quickly enough to meet the printing deadline.
Ah, that makes sense.
To exit momentary mode, it is necessary to disconnect power and wait until the driverâs residual charge has drained. If the button LED is lit up, it will drain that power in a small fraction of a second. But if the button LED was not enabled, it could take a few seconds before power is drained completely. Pressing the button causes the charge to disappear immediately. It does not matter how many times it is pressed or how long it is held. It only takes a few milliseconds. Anything after that has no effect.
It is probably not necessary to press the button at all though. Power should drain fast enough either way.
First of all, I think we have achieved to make a very profound, comprehensive yet understandable manual. I did not do most of the contentwise work, so credits go mostly to sbslider and stereodude. However, I took the liberty trying to answer to your points. Thanks for your input.
As Toykeeper mentioned already, there are references to BLF in the manual, especially on the very last column incl. credits to the BLF LT1 team.
Noted, but not a real issue that would require to edit the manual once again. However, I will try to consider it with the next update.
Not necessarily, as 5V is more or less THE standard USB charging voltage whereas higher voltages can still be used for special equipment (e.g. solar charging). Using 5V as a general recommendation for charging in the safety precautions will not be conflictive to a more detailed description in section "integrated charger".
I'm not a native English speaker but I guess "textured" would describe something else, like a certain pattern as in orange peel reflectors for instance. Opaque seems to be a quite common expression for a diffuse surface.
Not necessary, as the maximum length is stated with 70mm length. Both protected and unprotected batteries will do fine as the LT1 is not using an FET but constant current regulation with 5x 7135 AMCs.
Yes as this is a crucial prerequisite to safely run the LT1. Using flat top batteries can cause voltage imbalances and subsequent damage to the LT1.
Noted. I will try to consider it with the next update.
Noted, will be considered for future updates/manuals.
This topic has been discussed within the BLT LT1 team already and we decided to keep it this way. And yes, the LT1 will run at reduced output without batteries installed but with a USB-C energy source powered.
The default UI is STEPPED mode (like Toykeeper said already). This is a major difference to any other AndĂșril-driven light as these have SMOOTH RAMP by default. I agree with you that there is one spot I have overlooked - shame on me - in the specifications. Here it says SMOOTH RAMP by default. I will check with Sofirn if there's any chance to submit a correction.
See UI diagram for reference.
See Toykeeper's reply.
Noted, but not a real issue that would require to edit the manual once again. I will try to consider it with the next update.
This is already addressed on page 4 ("usage of the LT1 lantern").
No offense, but this is nitpicking, isn't it? ;-) To be more nitpicking, lower than 3.2V is not the same as 3.1V and lower. :-P
Noted, thanks. Will be rectified with another update later on.
Can you put me down for one more? For a total of 2. I think my parents that live in Africa need an LT1 for the nights with no power. Also, thanks SigShooter for all the admin work with the GB list. Itâs appreciated!
fneuf wrote:
Should the diffuser be described more as âtexturedâ rather than âopaqueâ?
Lux-Perpetia wrote: Iâm not a native English speaker but I guess âtexturedâ would describe something else, like a certain pattern as in orange peel reflectors for instance. Opaque seems to be a quite common expression for a diffuse surface.
Longtime user of American English here and sometimes I even manage to get it right. Hopefully this is one of those times.
Maybe better words to indicate the treatment could be âfrostedâ or âtranslucentâ. That type of surface is one that allows light to pass yet doesnât allow for clearly seeing through it and is done on a microscopic level. As Lux-Pâ wrote, texture is how something feels, mostly on a larger scale rather than a micro scale. There might be other ways of using the word, but thatâs the one Iâm using here without using a dictionaryâŠ
Excited, the long awaited BLF LT1 is ready
âFrostedâ and âtranslucentâ both describe the characteristics better than âtexturedâ or âopaqueâ. Opaque implies that it doesnât pass light at all.
The LT1 in the sofirn shop is really expensive, 99 USD without and 125.99 USD with batteries.
I estimate them to be early-adopter prices.
It really is. If thatâs their launch price, then weâre getting at a 50% discount via the group buy
Please put me down for 4 more. Total 5
Iâll take another one (Total of two)
Same here, I think 2 is a good idea. Can I update my request to 2? Thanks!
3 more for me please.
Would like to add one more to my order, I currently have spot 1308 and 1309, total of three.
Thanks
Thought I was on the list already, but I guess not, put me down for two please.
2 total please
Please put me down for 2, I think I signed up originally for 1. Thanks so much
If the price is 125.99 after the group buy then put me down for another for total of 2! Iâm at spot #2475 (IIRC)
Agreed! I will incorporate the latest (and hopefully very last) changes once again and submit Sofirn a revised version tomorrow.
All objections noted and replied above will also be adressed as far it is reasonable and possible. Thank you guys for your great help.
Hi all, I am quite confused, is the group buy price announced? Is there a code?
