Sofirn SP36, impressions of a sample
583 posts / 0 new
mavortium
Last seen: 1 year 1 month ago
Any thoughts on a UV mod of this light? Thinking of trying 4 × 365nm LEDs. Also, does anyone have the dimensions of the lens please?
hodor
hodor's picture
Last seen: 3 hours 41 min ago
I finally bought the LH351D Anduril version. It’s a lot heavier than I expected. I don’t have a Q8 and don’t look at weight ratings so don’t really know what I was expecting LOL
Overall feel is great, I love the simplistic design, although a SS bezel would be a nice feature. My only complaint is that the fins are pretty sharp. Same with the SP10S. Some chamfering would make them feel more comfortable and refined.
First thing I did was to open her up. I firstly tried soldering a wire and pulling but that didn’t work. In the end I went through the switch. Turned out to be pretty easy and wish I tried that first. Hardest part was unscrewing the switch without damaging it.
I’m now left with solder over the contacts from my initial attempts. I’ve tried removing it with solder braid and flux. Most of it got removed but some remains and has kinda just smeared into the grain. Any tips on how to completely remove it? Do I just need to get better solder braid?
Photo courtesy of Tom E
djozz
djozz's picture
Last seen: 42 min 28 sec ago
Put sand paper on the flat surface and start sanding, keeping the driver flat. The brass ring sticks out so that should work without problem.
hodor
hodor's picture
Good idea, thanks Beer
I’ve played around with the light some more and the voltage reading is off. Charging is ok and terminates at 4.2v but checking through the UI reports roughly 0.1v higher. IIRC the real value can be obtained by flashing some code to get the values to then tweak the “fudge factor” in Anduril?
I didn’t get a manual, should the switch led indicate low battery? Or does it only light up red when charging?
Barkuti
Barkuti's picture
Last seen: 1 hour 21 min ago
hodordjozz's suggestion is good but it should also work with solder braid and flux. You need to make sure the soldering iron tip's heat imbues well into the solder drops and the driver's brass ring, this means using a big tip with plenty of contact surface over the copper braid. The iron tip may need a very slight soaking, and of course plenty of flux over the surfaces.
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
djozz
djozz's picture
The entire ring may unsolder itself when made hot enough to melt the solder on top.
jasontheguitarist
Last seen: 7 min 33 sec ago
I still have some solder on the ring on mine, I used a braid to get most of it, then used a wide flat soldering tip to smooth the rest of the solder so it’s just a very thin layer. Works fine.
hodor
hodor's picture
That’s pretty much how I’ve left mine. I may sand it down at some point as Djozz suggested.
cengooo
Last seen: 1 year 9 months ago
hello my friend sp36 narsilm v1.2 on / off switch accidentally switched off no longer lit just lit when charging how to reactivate
Tom E
Tom E's picture
Last seen: 46 min 36 sec ago
On my 2nd SP36, the other night I tried the heavy gauge wire and pulling, as I did the 1st, but couldn't get it to budge this time. So, I removed the switch and hammered lightly on a pointy tool, like a thin ice pick, and it easily popped out. I knew though what part of the driver I'd be damaging, knew it was a safe area away from any components. It did get scratched up but no harm.
Re-programmed the NarsilM v1.2 with v1.3 and calibrated the voltage and temps so readings are now accurate.
SKV89
Last seen: 1 hour 41 min ago
Here are some measurements of the SP36 and SP36S that I bought during the 11/11/19 sale, taken with the Texas Ace lumen tube calibrated with Maukka lights:
Sofirn SP36 Turbo, 5172 lumens, 7103K, DUV -0.0142, CRI 74.9, R9 19.9, R12 51, Rf 64, Rg 102, Sony VTC6
Sofirn SP36 Turbo, 5094 lumens, Sanyo NCR18650GA
Sofirn SP36S Turbo, 4008 lumens, 5745K, DUV 0.0002, CRI 91.5, R9 54.9, R12 76.3, Rf 89, Rg101, Sony VTC6
Umpi2000
Last seen: 7 hours 42 min ago
What diameter is the driver for this light?
