I need help picking out and finding a portable generator. Hopefully some of you guys have experience with this. I do concessions, snow cones, funnel cakes, that type of deal. Some places I dont have power hook-up for my cords and need to bring a generator. I need it to have wheels, somewhere around 3000-4000 watts, quiet, dependable, easy to crank and maintenance, low fuel consumption. I use 2-3 deep fryers (they pull on average 1100 watts continuously running), a ice crusher (low wattage, only use when needed), sometimes light strings similar to xmas lights so nothing really there. Anybody have any suggestions? Hoping to spend in the $400 range or less. Thanks for any input, if you guys know of any forums or websites that would help in this subject I would appreciate that also. I love flashlights and making tummie's say yummie! Thanks for any and all input.
I looked around a lot a couple years ago and ended up finding a great deal on a used one (coleman powermate) that's too small for your purposes. Actually, I wish I'd gotten a smaller one.
Anyway, I suggest checking out the 'chondas' at harbor freight. The small ones had great reviews. They changed their engine line up since I was looking at them, but I owned one of the last kind they sold (but on a mower) and it was a total (good) rip off of a honda.
I was always told that propane generators were the ones to have because propane (as a dry gas) keeps the oil cleaner, longer. I have also been told that propane is also the easiest to start in cold weather and propane generators are quiet. I have only used one propane generator and it was really quiet and seemed to be really easy on fuel, even when powering two medium sized air conditioning units. Also, with a gas generator, you pay a road tax for gasoline.
Your power demands are pretty high, you can get a portable generator to handle that but it is still going to be big and quite heavy; not the kind of thing you will be man-handling onto a truck by yourself. I have had good luck with my 3600 Coleman, but like I said, its not easy to move around.
Honda and Yamaha each make high quality, true portable ones, but they are only rated at about 1100 watts. They are the size of a small lunch cooler, but more expensive than my Coleman.
great discounts are few an far between on generators. given your needs and frequency of use, I'd look into the warranty - like real the small print, contact them, google for problems w/ (and service on) the ones you're interested in.
I would recommend emailing these folks. They know a lot about generators and have always answered all of my questions for me. They have a large selection as well.
Tell them what you need and they'll help you pick one out
I've never owned a generator but when I lived in Alaska (23 yrs), almost every one of my hunting and fishing buddies that had a generator -- had a Honda.
Yeah 400$ makes it incredibly hard .If you want to use it I'd say spend the cash and get a good one .If you just want to think you might use it someday than buy anything .even used that are hard to buy .. just like trailers .
4000 watts for $400 is doable but anything with that high of output at that low of price range is going to sound like a riding mower at full throttle with the blades engaged. For the money, I'd be more likely to fabricate some brackets to mount a generator head under the hood of your tow vehicle and run it with a pulley from the engine's accessory drive sized to spin the generator at the proper rpm with the engine at idle (quiet). This way it's portable (goes anywhere your tow vehicle does), quiet, and doesn't require loading/unloading or fooling with any additional fuel.
That said, if you don't want to take on a project like that, a 4000 watt Harbor Freight generator for $329 and a homemade baffle box to quiet it down would be my second choice.
Can't help to say this but why not just heat using propane? From what I'm seeing you're trying to do energy conversion chemical->heat->kinetic->electric->heat, why not just skip the rest and do chemical->heat? That gives you way better efficiency.
My company has had great luck with the Northstar generators from Northern tool. We run the 15KW and 13.5KW for our 220V concrete grinders and they have been trouble free. The new line with the Honda engines are just awesome.
The only downside to them is they SCREAM at WOT. You would certainly need to make some type of secondary muffler system.
Hi Heggood...With that much power requirement, $400.00 isn't going to do it for you. As others have pointed out, anything you get for that price won't last and will make so much noise, you'll likely get kicked out of your venue. You're really in the range of a generator that I have which is the Yamaha EF3000iSEB, but this unit is $2,200.00+ dollars, which I know is much above your budget.
May I suggest you bite the bullet and increase your budget and purchase one of the Boliy Pro3600SIE models linked below. If you can't afford a Honda or Yamaha, the Boliy really is your only choice, especially if you want to lift it yourself, have inverter technology, and a generator nearly as quiet as the Yamaha EF3000iSEB. Hope this helps.
You never did mention if you need 240V. Keep your eyes peeled. I bought a brand new Generac GP5500 with 2 year warranty from HD last year for $380 shipped. It is a bit loud and heavy, though.
Richie, what's the difference between EF3000ISEB and EF3000IS. Specs look same except latter is $400 and 16 lbs less.
Hi Electroman, the difference is the ISEB version, which is what I have, has what's called, Boost Control Unit or BCU. When an excessive load is present, trying to start a large electric motor or large A/C unit etc., the BCU will add all the extra power of the 12 volt onboard electric-start battery into the inverter making it able to produce upwards of 3,500watts of power for 10 seconds. The standard EF3000IS does not have this ability and is only rated at 3000 watts maxium.
I can also tell you this generator is the most quiet generator you can buy, period. Just walk a few feet away from it while under load, it's nearly silent. It also has the Smart-Throttle technology. So the engine RPM is directly related to the load required.
Unfortunately, all this and more comes at a high price, but once you use it once, you'll never look back. The longest we have needed it in operation was during the summer of 2011 when a low grade hurricance or tornado hit this area of Long Island, New York. It ran for 34 hours straight and I believe we barely used 5 gallons of fuel, perhaps less.
The sad part was we still were not able to get a wink of sleep because our neighboor had purchased one of the Home Depot generators and made so much noise, all the surrounding neighboors started complaining. The funny thing was they thought it was our generator until I made them walk into our back yard, only to be blown away by how quiet it was.
BTW...I purchased mine about 6 years ago, back when they were $1825.00 delivered from Wisesales.com.
