Nope, overall runtime is the same and potentially higher. The benefits are a set output which gives consistent brightness, moderate heat and increased runtime when compared to a FET driver due to the set output. FET’s can pull more amps which drain the battery faster and create more heat. So if you want the highest output, use a FET driver. If you want longer runtime at a level below the max, a boost driver is better. It depends on your application.
PS, when your battery voltage gets low, charge it or swap a fresh cell in. Then you won’t loose any modes.
I also heard that Sofirn wants to work on an update of the SP33 but so far I don't know about any details.
I agree with BurningPlayd0h that using FET over a 6V boost driver would be quite a downgrade. IMHO, there's not much of a benefit in using a 3V XHP50.2 instead of the 6V version. All you might get is a bit more lumens in the beginning, causing the host to heat up way earlier as currents will be far above 5A compared to the 6V boost driven version. In return you get a much uglier beam pattern (greenish tint shift with coldwhite CCT only) and no regulation at all, i.e. brightness will diminish as the battery voltage drops.
I admit that "losing" modes feels a bit odd when used to FET-driven lights but this is how Sofirn designed the UI/stepdown regulation. In terms of improving the driver they might be able to finetune its stepdown voltage thresholds a bit less conservative, leaving more room for high-current cells to maintain a reasonable brightness level.
TL;DR...my suggestions for an update of the SP33 would be:
improved assembly QC (some SP33 show hazy/milky coating on the inner side of the lens)
USB-C instead microUSB charging port
improved boost driver voltage thresholds for longer runtimes on Turbo/High modes
improved tactile feeling of side switch (less cushy)
omission of timed stepdown and usage of thermal regulation with at least 55°C as threshold
@Barry0892: Any news about SC31A?
Is there a plan to add moonlight mode, preferably <3 lm ?
If so, will this moonlight mode be available from off (i.e. long press) ?
Depends on how concentrated the hotspot is. 10lm from a full-flood zoomie has so low lux that it might as well be moonlight. Only difference is that it (eg, my Cometa) lights up a way wider area than a regular light with concentrated hotspot. 1lm from a C8 or GTmini would be painfully bright.
My E03 with heavily-diffused film in front also spreads out the light over a wide area, so even its “low” is quite low. Of course, starting on medium kinda kills night-vision anyway, but…
I disagree, when I’m using moonlight its almost exclusively to light up things that are close to me (sometimes right in front of my face) so even a very floody beam will be fairly concentrated at that range.
This might be the wrong topic im posting in here, but the Sofirn C01 used to come with a nice 3200k Yuji LED, now the C01S comes with a 4000k SST-20 which i dont doubt is also very nice.
The thing is im only really interested in a 3000k (or close) AAA high cri flashlight, does anyone make those nowadays?
Or is there a place where i can still buy the C01 with the yuji warm white.
Are there any plans for a new sofirn AAA flashlight, maybe even a 2700k one?
id love to add a AAA to my collection but i have a hard time justifying it seeing as i already have other 4000k lights and i would love a really warm white compact flashlight.
Maybe there is a place i could buy an incandescent flashlight from china somewhere? i own a few incandescent lights and i adore them but there are all simply too large to carry for the little light they give off.
Im sure you could fit an E10 incandescent bulb into a AAA form factor light, i might even try to make my own. but i dont know of any AAA flashlight host that would allow that.
@ Petelele: Sofirn C01 with Yuji warm white has been discontinued. I don't have any information if Sofirn is ever going to produce the C01 with a 5mm LED again. Maybe they could try using a different 5mm but my guess is they prefer to be using high power LEDs like SST-20 as in C01S only.
This is however neither HighCRI nor anything around 3.000K CCT. Maybe Sofirn could consider using SST-20 2.700K 95CRI for their next batch of C01S. There are plenty of nice options for this great AAA flashlight host.
bloody shame, the red LED really interests me, however i have a red led on my mini Victorinox swiss army knife, and if i really need more than that i feel like id have to bust out at least a 14500 flashlight, not a co1s with a red LED, it looks great but spending 10 euros on that thing just seems like a little too much for what would probably end up being a novelty item.
though i really like aux LEDs too… both would be nice
