Please confirm that these are a good choice for protected cells for LT1?
Decided to go with protected cells as I have 3 young kids and while I’ll teach them not to play with it, it’ll give me peace of mind that if one of them (or their friend etc.) did open it & reverse the cells then there’s an extra layer of safety.
I’ll try to help. Not sure what your question is on the switch backlight, I didn’t go back and read all the posts closely, please ask a detailed question. As far as your 3 questions on the ramped configuration section go, 1. That’s the way ToyKeeper designed the firmware. default is level 80 for smooth. In stepped, the region between the bottom and top of the stepped range are user configurable, and the firmware divides the region up evenly depending on the user’s choice of steps. ToyKeeper chose the defaults listed. For stepped ramp, the default is the level closest to level 80, which is 65 for her design of the default. Hope that explains it. 2. Hmm, not exactly sure what your asking. The defaults are listed on page 2 of the english version in the section called Ramp Configuration, 3rd paragraph. Is there more your looking for? All of this is user programmable, so once it is changed by the user the “defaults” change. 3. The grammar in this question is hard for me to understand. I think the answer is that’s the way ToyKeeper programmed it. You can never change the level wanting to default to at (smooth ramp) or near as possible (stepped ramp). You can change the bottom and top of the ramps independently for each ramp type, and the number of steps for the stepped ramp, but not the default level at which the lantern will turn on with a single click after the battery is replaced. Once the user changes the factory defaults, they can be reset, but I don’t think that got put in the manual as to how, at least I didn’t find it at glance right now.
[/quote]
Many thanks guys, really. I now understand what was previously missing to me. I can finish to translate that and making sense. Great job!
Small detail for STEPPED: so that does mean that, the user defined # of steps is persistent after power loss?
Yes, that is correct, the if the user changes the number of steps from the default (5) to another number, that updated number is saved when the power is removed.
I read somewhere that these are being produced in batches for our group buy. Can anyone shed some more light on this and how this process will play out?
Et voilà, the french translation (PDF) is officialy available for public release, now crossing my fingers to meet Sofirn Batch#2 printing schedule.
Thanks to the original writers of the manual, and thanks again to all of you who dared to risk your lifes answering me in the last pages.
Please consult the linked PDF directly (that should also be soon available from the usual shared repository), as I did not regenerate PNG extracts this time, and feel free to propose suggestion and correction.
For next international updates of the LT1 operation manual, I'd like to propose to factor in some info about some physical aspects. Like the metal support ring and standard tripod holes.
Perhaps you should update the first post to include the fact that this forum has a “Click to Subscribe” button in a big, obnoxious font.
At that rate the thread is a mess…
Would you be willing to make my total request of LT1’s - Two (2) ?
Below is copied from the spreadsheet to make finding me easier if needed.
1202 russthetoolman 1 2163
Thanks !!
Russ
