Review copies was sent in by Angryfox to me here in the Philippines, whom I thank for the confidence afforded to me.
Preface:
Angryfox sure knows how to be playful as well! The Playfox K1 and K1s is a very small, compact keychain fun light by Angryfox. It is a keychain light with a set of three different colored diffusers which makes it unique and somewhat cool.
Packaging:
It comes wrapped in bubble wrap, secured well in the transit box in a matte white retail packaging with gold foil stamped accents on the sides, and at the back are the colors available.
Some information can be read on the front of the packaging just below the two plastic windows which lets us see a preview of the light inside the box along with the three different colored diffusers.
Inclusions:
1x Playfox K1
1x Manual (English and Chinese)
3x Silicone Diffusers (red,green,blue)
Quick Features and Specs:
-Digitally regulated output that maintains constant brightness
-Designed with mechanical anti-reverse connection
-Designed with PMMA lens
-Has 3 colored silicone diffusers
-Has over-heat protection that avoids high temperature on the surface
-Utilizes a CREE XPG2 R5 LED with a lifespan of 50000 hours
-Runtime of 110 hours
-Has a warning light function
-Weighs only 10 grams (w/o battery) , the sus version is 21 grams
-Max output of 100 lumens
Operation:
Twist the tail cap tight to turn ON the light. Twist counter clockwise to turn OFF, then clockwise again to change modes.
Modes:
Starts with MED-HIGH-LOW, then again MED-HIGH-LOW, then warning light.
Form Factor:
This is a very compact, simple, small keychain light. It is very smooth, sleek and flawless design from head to barrel.
Head:
The bezel has 3 groups of groves, possibly cooling fins, all around it that helps with heat dissipation.
The lens are clear, with a polished smooth reflector.
On the center is the LED perfectly situated.
Barrel:
The barrel is sleek and smooth, with a grove near the head to secure the silicone diffuser. The model can be clearly read on one side.
and the brand written on the other side
The threads are mildly lubricated as well as the o-ring.
Diffusers:
The diffusers are three (blue,green and red),
which have a small circle shaped hole in the apex of the diffuser to somewhat let light through for illuminating a greater area.
Tail:
The tail end is one with the barrel on this light, and a little conical, slightly pointed in shape, attached to it is the small keyring.
Side by side:
Beam shots:
LOW 5 feet away:
MED 5 feet away:
HIGH 5 feet away:
LOW 20 feet away:
MED 20 feet away:
HIGH 20 feet away:
Conclusion:
To sum up, I believe that the most important part of any review is if given the chance to purchase the same light for my own EDC, would I still purchase it?
For this light, it is a definite YES. Specially if you are looking for a small, compact and most of all fun keychain flashlight with complete functions.
Scrutinizing the light over throughout the review, I am hard pressed to find any flaws at this price point. If I were to nit-pick, it would be the mode functions, it is somewhat weird for me that it starts of in MED, then going to all the modes again MED-HIGH-LOW to go to the warning light, they should have just made it by twisting it fast two times to be able to go to the warning light function. But overall, on this price point, and the light quality and lumen output, I would say that this is clearly a good value for money, specially if you are into twisties! Awesome fun light by Angryfox!
As with all gears, two is one and one is none.
Light on brothers!
Here is my video review for this light(please don't forget to hit the thumbs up button and subscribe):
https://www.youtube.com/watch?v=E0H70kOPwy4&t=57s
Angryfox webpage:
https://angryfoxlight.com
Check out my Facebook page for coupons, discounts, reviews and upcoming lights!
www.facebook.com/torchesinternationale
My blog for more written reviews: https://sacrileizei.wordpress.com
And my youtube channel for more video reviews on lights and other EDC items:
https://www.youtube.com/channel/UCmxATh4QVS-GaUy60jR6GUA
