Customer Review for Hot recommend RD tech (ruideng) products of DPS5020, DPS5015,DPS5005, UM25C ,UM34C ,TC66C UM24C at34,DPH5005
107 posts / 0 new
BlueSwordM
BlueSwordM's picture
Hello RDTech.
I’ve been loving your products, but I’ve been having a small problem.
Using it during chemistry experiments, it has been very useful.
However, being exposed to corrosive vapors on the outside, the outside case screws have started to rust after 9 months.
Could you provide measurements for the screws so I could buy stainless steel or titanium ones?
Thank you.
Edit: This was for the DPS5015 case. Sorry if I did not include it.
RD tech
RD tech's picture
Last seen: 9 hours 39 min ago
Hi friend
thank you so much for your message and your support
could you tell me which case you bough? metal case or aluminium alloy case?
i can provide the instruction, there is screw model name
If you have any interest in USB tester or power supply, please contact me
this is my shop on Aliexpress: https://rdtech.aliexpress.com/store/923042
BlueSwordM
It is the metal housing case, like on your DPS5015 product page.
RD tech
RD tech's picture
B.choice 2 (suitable for with power board part product): https://www.mediafire.com/folder/rsbgws8grh6zo/communication_metal_houin...
you can check this instruction
RD tech
RD tech's picture
NEW SHARE
RD TC66C USB-C Voltmeter ammeter
[This is not the first device from this store and once again everything is almost perfect. To packaging and delivery without claims. The quality is also good. Great device with triggers on board. There is a connection to the PC via micro USB and the ability to upgrade firmware. In general, I am satisfied, I recommend.]
https://www.aliexpress.com/item/32968303350.html
RD tech
RD tech's picture
NEW SHARE
RD DP50V5A Constant Voltage current Step-down Programmable Power Supply
[Product Works Perfectly. No Issues so far Found. Fast Shipping. Recommend Seller!]
https://www.aliexpress.com/item/32596330856.html
RD tech
RD tech's picture
NEW SHARE
RD DPS3012 constant voltage current step-down power supply
[the goods arrived in 2 weeks as I recommend in the description]
https://www.aliexpress.com/item/32685179404.html
RD tech
RD tech's picture
NEW SHARE
RD DPS5020 Constant Voltage current DC- DC Step-down communication Power Supply
[It is functional , I am completely satisfied with the device. Built into the case from the uninterruptible. Delivery is fast, packaging is excellent.]
https://www.aliexpress.com/item/32821185351.html
RD tech
RD tech's picture
NEW SHARE
RD HD25 Trigger QC2.0 QC3.0 Electronic USB Load resistor
[Delivery - 1 month to Bulgaria. Perfectly packed! Fully consistent with the description and works fine. I recommend! Many thanks to the seller !!!]
https://www.aliexpress.com/item/32917594486.html
RD tech
RD tech's picture
NEW SHARE
RD tech
RD tech's picture
NEW SHARE
RD DPS3012 Constant Voltage current Step-down Programmable Power Supply
[Everything is super! Works great! I recommend the store and the seller !!!]
Bill_tong
Last seen: 4 months 4 hours ago
When are you releasing the 60v 5a programmable one you mentioned on this board 2 months back
RD tech
RD tech's picture
it will be soon, we are waiting for the raw material
RD tech
RD tech's picture
NEW SHARE
RD DPS5015 communication Constant Voltage current DC Step-down Power Supply
[Good Protect good seller fast shipping goods arrived for India 20days thanks RDS protect & company test 100% working Thanks]
https://www.aliexpress.com/item/32702714880.html
RD tech
RD tech's picture
NEW SHARE
RD DPS5020 DC Step-down Power Supply
[Emotions are positive! The seller is very sociable. Helps than it can. The device gives out its 20A and works normally from 50V input voltage. Alas, I use the source HJS-480-0-48 (500w). Either voltage or current. A kilowatt far, but enough for me. I can only say that at the output I used my wires (10mm²).]
RD tech
RD tech's picture
NEW SHARE
RD UM25C voltmeter ammeter
[fast delivery does not support at the time of order, by default only an e-packet was available, it is impossible to imagine a longer delivery plane for a longer delivery, literally they carried it from China. and let this device be beautiful a thousand times, but delivery by e-packet has made a lasting impression. but the seller controls everything]
https://www.aliexpress.com/item/32855845265.html
