ANDURIL USER MANUAL & LIST OF LIGHTS
This really has me thinking. Most people have only ever used flashlights that click to turn on and maybe go through a couple brightness levels with additional clicks and then off. So it’s not surprising that if you handed someone an Anduril flashlight, they would start clicking away. They key here is communication. “Click once to turn it on, then click and hold to ramp up the brightness” is all it takes. Putting the light in Muggle mode before handing it over and giving the same verbal instructions is even better. Muggle mode is a selling point for me, please don’t remove it. I can see making it 6H for both enter and exit, but please don’t make it a different click sequence for exit than it is for enter. I will never give a child a flashlight capable of starting fires even with Muggle mode.
Add 4H from lockout for “exit lockout and immediately start ramping up from the floor”. Love this idea!!
It’s why my idea is to have the last memoried brightness as max brightness in Muggle mode. When giving it a child, you can set brightness to 50% and then 6H for Muggle mode, but when borrowing it to someone on camping, you can set 100% and then go to Muggle mode.
There are already two official forks of Anduril — RampingIOS V3 and Fireflies UI. They don’t get updated much, since it’s kind of a pain merging changes back and forth between related forks, and because I often don’t really think about the other forks when making changes. Also, RampingIOS V3 has been abandoned by its sole stakeholder, so I haven’t bothered keeping it updated.
I have no intention of removing the stepped ramp. I use it too. I think the request was only about muggle mode though.
I’m undecided on that one. The idea is, if the enter and exit sequences are different, it’s easier to help people who managed to get stuck in muggle mode. They can be told “just click 6 times, but hold the last click for a second or two”, and it will put them into a predictable state. But if the enter and exit sequences are the same, it can be much more confusing for both the person who is being helped and the person trying to help them.
OTOH, mapping both to 6H means it’s unlikely people will get there by accident… so maybe there wouldn’t be as much need to help people who don’t know which mode they’re in.
I don’t really want to add features to muggle mode… if anything, I’d like to reduce it back to its original form — on/off only at ~100 lumens.
If I’m still working on this in 20 years, the changes will probably require a lot of expertise to even understand. They’ll probably look somewhat like this…
I mean…if people want it, but in my opinion this way it’d be less used - only 100lm is quite low. When I think about use of Muggle mode, it’s like:
camping
“Hey, could you borrow me your flashlight for a while?” “* set to Muggle mode * Sure, take it”
With 100lm on off only there’d be not much use of that flashlight. I’m wondering what people think about this “last memorized brightness for max level”, it’s what I found very useful at least, covers “children use” and “friend use”.
I don't think it's a good idea: IMHO Muggle mode should - by definition - be a "safe" mode under all circumstances, i.e. the light should neither get too bright nor too hot to injure or even scare a complete Muggle of a user.
Personally I would vote for something along the lines ToyKeeper suggested .. simplified click for on/off and hold for a (circular, ZebraLight-style L-M-H) 3-mode stepped ramp with 3-30-300ish lumens and no other features because that's about the maximum complexity I would trust a Muggle to handle.
Maybe it's a good thing tho.. ? Like in.. "trial by fire" ? Basically leaving the main branch mostly as is and if say.. "Anduril Alt" or another alternate fork isn't doing too well, just abandon ship.
So maybe something like: the last memorized level is the max, but no more than 800lm? Or other value, 600? So when giving it a child, set it to 100lm, because 300 could be sometimes too high, but when giving it a friend just set it to 600 and tell: It is bright. Be careful.
As long as you are setting brightness level before giving it, it is safe.
If my idea is in fact bad, please TK make it something more than just on off, 3 modes as mentioned are ok. But 100lm max is just…meh.
And after all very intensive thinking I decided it would be better to have 6H both for enter and exit from Muggle mode, as mentioned. :slight_smile:
camping
“Hey, could you borrow me your flashlight for a while?” “* set to Muggle mode * Sure, take it - click to turn it on and click and hold to change the brightness”
Having said that, Muggle mode would be better IMHO if it used single clicks to cycle through a few brightness levels, just like most ordinary lights work. Click for on, click for low, click for medium, click for high, click for off. No push and hold to do anything. If it worked like that you could put it in Muggle mode and hand it to anyone and they would understand it without any instruction.
The reason why it uses a simplified smooth ramp is because a vote was held to determine muggle mode’s UI style. Here are the results:
1
2
3
4
5
  1. Smooth ramp
70
76
78
85
  1. 3-mode Baton
40
68
62
61
  1. 1-mode
36
35
63
51
  1. None
37
43
41
56
  1. 3-mode clicky
25
37
47
51
So basically smooth ramp was the most popular, then stepped ramp, then on/off at a single level. Then the option of removing muggle mode entirely. Coming up last was the style where people click to change the level, including “off” as one of the levels in rotation.
My personal preference is:
  1. None
  2. 1-mode
  3. Smooth ramp
  4. Stepped ramp (3-mode Baton)
  5. 3-mode clicky
But that’s mostly because I’d rather use that space for other things. :slight_smile:
Quick idea.. Not sure if it's the right place, but here goes..
So one of the latest additions/changes in Anduril were the 5C & 5H to choose between Manual/Auto On Memory and also, the 2C from Off changed from a Turbo shortcut to a Ceil shortcut
That just made me think.. why not combining these into something as follows:
- 1C - Revert to Auto Memory (basically whatever brightness state you've left your light Off, it should be memorized for the next Poer On by 1C - pretty much the old behavior)
- Remove either 5C or 5H and leave only one of them as the Manual / Default On Memory - Say.. Ramp to whatever you want > and 5C would memorize that level..
- Remap 2C from Off (Ceil Shortcut) to the memorized Manual / Default On Memory - also this way you are avoiding a duplicate 1C/2C (Turbo wasn't a Manual memorized level anyways)
So.. 1C - Standard Auto Memory / 2C - Manual / Default Memory - This way, you still have the Manual On Memory and a configurable pre-set level of brightness (Up to Ceil if needed)
The way Turbo was reached in the latest revisions was still 2C > 2C anyways, regardless if 2C was straight to Ceil or if by the above, it would be configurable to something else.
Thoughts.. ?
That didn’t change. It has had the same behavior since literally day 1.
It’s very unlikely to change, because it would eliminate one or more of the core UI requirements the design was built around. The idea was to provide, at minimum, the following:
From off:
  • A shortcut to the lowest level.
  • A shortcut to the highest level.
  • A shortcut to the memorized level.
While on:
  • 1 click to turn off.
  • An easy way to go up in brightness.
  • An easy way to go down in brightness.
  • A shortcut to/from turbo.
Those things aren’t going to change. The user can configure the meaning of “lowest”, “highest”, and “memorized”, though.
So, I don't really follow.. about the 2C from Off shortcut - that didn't changed since Day 1 as in it was always a shortcut to Ceil or always a shortcut to Turbo ?
In the anduril.txt I can see it was always a shortcut to Turbo.. ?
From off it’s a shortcut to ceil, from on it jumps to turbo.
I just got my Sofirm SP 36 BLF and was going through Anduril menu. I need a little help.I am trying to find steps to dim the locator light on the switch. Is it possible to do this? Just trying to save battery drain. Thanks
From Off, 7C (7 quick clicks) cycles you to the next switch backlight mode.
The modes should be Low, High, Flash/Breath, and off.
(not necessarily in that exact order)
If 7C from Off doesn’t do anything, are you in Momentary or Muggle mode?
My wife is a bit of a horror freak, Walking Dead is her fav series, curiously she also binge watches the Hallmark channel.
Anyway she has set up a graveyard scene on our front yard, 7 tombstones top off piles of leaves shaped as fresh dug graves, complete w/skeleton climbing out of one of them. She asked iffn I could light it for her. I showed her the lightning feature of Anduril……
Now I’m waiting till dark to go out in the chill air and play roadie lightshow guy with a ROT66, E07 and D4V2 positioned in various trees around her macabre creation.
I accidentally changed the smooth ramp config, now it goes up all the way to turbo. Please help me go back to default.
The procedure is to click 4 times while on the smooth ramp mode.
Then 1 click on First prompt(floor).
Now How many clicks on 2nd prompt(ceiling) to go back to its default from factory?
Thanks TK
Iirc, default max ramp is 120 out of 150 thus, 30 clicks.
Should be something like. turn it on then.
  1. 4 clicks to enter Ramp config
  2. 1st flare, do nothing
  3. 2nd flare, click 1+Turbo - N. That is default ceiling 120/150, so click 30 times.
120 is right but it takes 31 clicks (1st click = 150).
I did that wrong a couple of times myself.
