Highly unlikely. I’m guessing it ramps all the way up to 600 lumens. I don’t see the point having a higher turbo being a lantern that’s designed for runtime
I believe anyone can order from aliexpress at any time without a PM as long as their name is on the list.
Just an opinion of mine…. having the LT1 available from Amazon with a PM’d code as well as being available on eBay and aliexpress is very confusing. I know this ordering process is completely out of our hands so this is just a statement for future consideration by anyone else involved in a project.
If anyone on the list can order from ali or ebay at anytime what is the point of the numbered list? It becomes a free for all.
This is correct. The LT1’s primary purpose is to be ‘enough’ lighting to let you function normally over an extended time. In a situation where normal lighting is not available, this should be enough light to allow it. It was never designed to replace a 200w chandelier.
That said, there are - I believe - solder pads on the driver to let those who want to trade runtime for more light. If the details are not in the instruction manual, dig through the first post and you should be able to find them. You’re not going to hit 4 digits of light, but you can get ‘more’.
I’m pretty sure you’re both incorrect. We went over this when working on the manual. As it was explained… By default the light does not ramp all the way to the max possible output. It ramps to the “ceiling” which is not the max possible output. As such, the “turbo” is brighter. You can change the ceiling to the max possible output, but that’s not how it ships.
Of course it’s always possible that we were given incorrect information despite making every effort to ensure the accuracy of it.
Anything is possible… The manual now says that the ramp goes all the way to the max possible output level. It also says there’s a turbo mode. I can’t vouch for the accuracy of it.
TK may have changed the final release of the firmware for the production units, i am unsure of that. but the production prototype i been testing has a smooth ramp that goes from roughly 10% up to 90% brightness, the 90% being the ceiling of the ramp config. A quick double click brings it to 100% maximum. Technicallyit is not a turbo as it don’t step down & is not a “overdrive” mode like some flashlight turbo modes are considered. The stepped ramp config goes to 100%
Did anyone succeed in ordering from ebay? I made an offer on the lamp with batteries and included info (didn’t get a code yet) but I didn’t get a pm and the offer has not been accepted. Do I need to wait for the next batch? I got no issue with that I just want to get it ordered so I’m not forgotten
@DBSAR…With list of upcoming accessories for LT1 ,only thing missing is to make LT1 swim…Can we add a floating accessories to LT1
On serious note,my hats off to you and others involved in project…you guys are bunch of inspiring individuals.
