NEW SHARE
RDUM34C USB 3.0 Type-C DC voltmeter ammeter
[Ordered the parcel sent the same day. The seller is responsible immediately packaging is excellent. I went to the center of Ukraine for 28 days. the device is an excellent box for transportation is excellent. I will do a review on my YouTube channel Techno live channel. and recommend.]
https://www.aliexpress.com/item/32880908871.html
NEW SHARE
RD AT35 USB 3.0 multimeter
[Delivered to Croatia in 2 weeks. USB meter has beautiful display and is very practical and easy to use, comes in a nice plastic box with foam which is great for storing and carrying around. USB load meter is nicely put together, and is also easy to use. I would suggest putting better plastic standoff legs and perhaps knob on a potentiometer. Also foamy box so that it doesnt flap inside. Overall, very nice products for amateurs and pros. I will order more in future. Love this seller and their products.]
https://www.aliexpress.com/item/32897200670.html
NEW SHARE
RD DPS5020 Constant voltage current DC- DC Step-down communication Power Supply
[I liked the device, for a long time "lay" in "My wishes." So far, it has shaken by about 250 - 280 watts, although it is possible up to 1000 watts. There is no more power supply yet. All the declared parameters work, on the bluetooth of the device it connected without problems to a smartphone and laptop. By USB, too, no problem. A small minus, in my opinion, is a constantly noisy case fan. I can recommend a great device! I ordered the maximum configuration of the DPS5020.]
https://www.aliexpress.com/item/32821185351.html
Hello RDTech.
I’ve been loving your products, but I’ve been having a small problem.
Using it during chemistry experiments, it has been very useful.
However, being exposed to corrosive vapors on the outside, the outside case screws have started to rust after 9 months.
Could you provide measurements for the screws so I could buy stainless steel or titanium ones?
Thank you.
Edit: This was for the DPS5015 case. Sorry if I did not include it.
Hi friend
thank you so much for your message and your support
could you tell me which case you bough? metal case or aluminium alloy case?
i can provide the instruction, there is screw model name
It is the metal housing case, like on your DPS5015 product page.
NEW SHARE
RD TC66C USB-C Voltmeter ammeter
[This is not the first device from this store and once again everything is almost perfect. To packaging and delivery without claims. The quality is also good. Great device with triggers on board. There is a connection to the PC via micro USB and the ability to upgrade firmware. In general, I am satisfied, I recommend.]
https://www.aliexpress.com/item/32968303350.html
NEW SHARE
RD DP50V5A Constant Voltage current Step-down Programmable Power Supply
[Product Works Perfectly. No Issues so far Found. Fast Shipping. Recommend Seller!]
https://www.aliexpress.com/item/32596330856.html
NEW SHARE
RD DPS3012 constant voltage current step-down power supply
[the goods arrived in 2 weeks as I recommend in the description]
https://www.aliexpress.com/item/32685179404.html
NEW SHARE
RD DPS5020 Constant Voltage current DC- DC Step-down communication Power Supply
[It is functional , I am completely satisfied with the device. Built into the case from the uninterruptible. Delivery is fast, packaging is excellent.]
RD HD25 Trigger QC2.0 QC3.0 Electronic USB Load resistor
[Delivery - 1 month to Bulgaria. Perfectly packed! Fully consistent with the description and works fine. I recommend! Many thanks to the seller !!!]
https://www.aliexpress.com/item/32917594486.html
NEW SHARE
RD DPS3012 Constant Voltage current Step-down Programmable Power Supply
[Everything is super! Works great! I recommend the store and the seller !!!]
When are you releasing the 60v 5a programmable one you mentioned on this board 2 months back
it will be soon, we are waiting for the raw material
NEW SHARE
RD DPS5015 communication Constant Voltage current DC Step-down Power Supply
[Good Protect good seller fast shipping goods arrived for India 20days thanks RDS protect & company test 100% working Thanks]
https://www.aliexpress.com/item/32702714880.html
RD UM25C voltmeter ammeter
[fast delivery does not support at the time of order, by default only an e-packet was available, it is impossible to imagine a longer delivery plane for a longer delivery, literally they carried it from China. and let this device be beautiful a thousand times, but delivery by e-packet has made a lasting impression. but the seller controls everything]
https://www.aliexpress.com/item/32855845265.html
