It is one of my favorite lights these days. The output is around 115 watts in such a small host. I can’t discribed it with words, you must see it yourself. This is a must buy.
I think that is correct, double click does not do anything except that sometimes it hits strobe. If there is a brighter turbo than the high setting, you could set the world on fire
Yh he cancelled it due to driver issues but now the D1Sv2 is about to be released so I think he might also continue with d1s+. Well he should anyway since the d1sv2 will be a much larger light and not very pocketable.
So after reading the reviews on here… I’m curious about the throw. I know multiple emitters are always on the flood side, but does th light at least reach 100 feet or so?
If you notice, most of our “hype” flashlights are non-sense, the emisar d4 and d4s overheat itself when on turbo, the BLF GT is ridiculously big and heavy.
I buy this light not for using everyday, but to make my friends “wow” when i show it to them
I dunno if I would have bridged the springs. In this case I don’t think it would noticeably increase output, but rather take a light that already gets super hot super fast, and make it heat up even faster, and probably reduce the life of the led. Just my two cents.
