NIGHTWATCH NSX3 9900lm 21700 LED Flashlight NS53A 6500K 9900lm
It is one of my favorite lights these days. The output is around 115 watts in such a small host. I can’t discribed it with words, you must see it yourself. This is a must buy.
Robert
Hey scosgt, is turbo really in the mode sequence? Usually it’s double click for turbo,so this light has double click for strobe?
I think that is correct, double click does not do anything except that sometimes it hits strobe. If there is a brighter turbo than the high setting, you could set the world on fire
Yh he cancelled it due to driver issues but now the D1Sv2 is about to be released so I think he might also continue with d1s+. Well he should anyway since the d1sv2 will be a much larger light and not very pocketable.
So after reading the reviews on here… I’m curious about the throw. I know multiple emitters are always on the flood side, but does th light at least reach 100 feet or so?
Have this flashlight memory for mode?
This Picture: https://cdn.shopify.com/s/files/1/0031/0155/6806/products/60f2956ffa544f83a2ab6d6e973c140b.jpg?v=1569859207 sais “yes”
30m no Problem, it seems that after 60m there is still light, but, of course, the main light output hits the short distance in front of you.
35amps in that tiny host ? lmao… whats the point even ? for that much lumens u need alot bigger host to even manage so high lumens.
Trust me, this light is a bomb. Every flashaholic must have it. It starts dark paper within a half second on fire.
Robert
“Too much of everything is just enough.” :slight_smile::slight_smile: :partying_face:
He called you a total crank. :laughing:
Hey, is the GB over? I lost track of it somehow, was interested in one…
Don’t think so… I bought one just a few days ago. Shoot Martin a pm
If you notice, most of our “hype” flashlights are non-sense, the emisar d4 and d4s overheat itself when on turbo, the BLF GT is ridiculously big and heavy.
I buy this light not for using everyday, but to make my friends “wow” when i show it to them
well yes true, but that much lumens in small host is kinda a bit overkill imo…
Can’t the LEDs be dedomed for a little more throw?
Yes. But I’m not sure it would increase very much being that the reflectors are orange peel and not very deep.
I dunno if I would have bridged the springs. In this case I don’t think it would noticeably increase output, but rather take a light that already gets super hot super fast, and make it heat up even faster, and probably reduce the life of the led. Just my two cents.
you’re clearly in the wrong forum, pal :smiling_imp:
Got mine. It’s a really stupid flashlight. No memory mode
