Being bothered by this is white wall hunting at its finest I have this ring on my Nichia S2+ and my XM-L2 S2, and it doesn’t affect their utility in the slightest.
Aint no white wall on this
Or should we paraphrase “bothered by tints, cri or pwm is whinning at its finest when it doesnt affect their utility” when the big bad barney the purple dino halo ring is hugging your light :innocent:
Why none of these reviewers mention it or a ring that i can easily capture on my iphone camera doesnt show up on THEIR white wall beam shots is beyond me
I have no comment.
I just hope this thread keeps going because it puts a smile on my face.
I just realized I do have a comment.
Halogate.
I can give you a shipping address to dispose the flashlight if you want.
Not a chance, im going to shine it on folks to make em seem like they are religious figures with that halo :innocent:
Great for night church sermons !!!
A special convoy s2+ feature … instant jesus
@Bearbreeder, that’s a constant complaint about the SST-40, exasperated by the low CCT and low CRI of the SST-40.
The SST-20 4000k is much better in this regard.
Thats interesting as we have folks here and on reddit who seem to have the same issue on the s2+ with sst20, nichia, xml, etc …
Perhaps not purple but pink, red, etc …
Its not just AR lenses as my fenix and blf a6 with em dont have this issue
What amazes me is not that its there, its a cheap light afterall
But that ALL the reviewers seem to miss it while they go off about tint, cri and pwm
Its the more obvious than any of those on mine :innocent:
get the OP reflector if rings bother you. s2+ with sst20 and OP. no rings and perfect hotspot.
Whats “bothering” is the absolute lack of mention of this in reviews
Are reviewers getting set “special” samples, are their cameras not able to capture what an iphone camera can, or is it something else …
How can one be a tint snob and not see a big halo?
My D80v2 with SST40 has a similar distinct blue/violet ring around the periphery of the beam. It’s noticeable but in no way affects the usefulness of the light. It resides outside the useful area of the beam and isn’t a problem in actual use.
In practice, it doesn’t really affect tint/CRI since it lands far outside the usable light pattern.
For what it’s worth, I have an S2+ with a 219c which does not have any visible blue artifacts around the beam.
Pretty noticeable on even a brown fence
Might not be in the beam itself but its well in direct view of your eyes
Its amazing that reviewers dont seem to even mention it when they go gaga over every other thing
I guess we don’t see it mentioned because it doesn’t really affect the performance of the light. If it was right around the hotspot we’d probably see many people complaining about it. It’s far enough out that it’s easy to just ignore it.
If it really bothers you, perhaps you could try a different reflector/optic or perhaps a non-AR coated glass window. If that doesn’t help, consider a different emitter.
Its because the reflector shape is not perfectly optimized for the LED. If you want a clean hotspot you need to use TIR lens. But it will be less bright.
And yet it doesnt even show up on white wall beam shots of reviewers … where it easily shows up even outdoors on mine
And big purple halo is like barney the purple dino stalking you
Looks like the BLF A6 has the proper reflector, it is AR lens
Compare to the s2+ sst40
Hes coming for me !!!
+1
Heres whats very interesting … no purple halo, and a good reviewer would have mentioned it
Blf a6 … no purple halo
Convoy sst40 s2+ … pretty obvious on a beam shot, no sense whining bout tints or cri with that thing around
And …
I’m pretty sure reviewers don’t mention it because it doesn’t effect the usability of the light like tint, CRI or PWM may. Nobody uses the uses the area outside of the useful spill of a light to do anything. At any rate, the halo is from a combination of AR glass and the bezel of the light.
Blue Convoy S2, No AR glass. Deep blue halo like yours. Green halo from very thick GITD Oring.
Green S2+, AR Glass, TIR (Triple). Green halo
Purple S2+, AR Glass. Huge purple halo
Black S2+, No AR glass. No halo
Desert Tan S2+, AR glass. Brownish-orange halo, pretty faint.
Silver S2+, AR glass. Bright blue/purple halo.
Thanks for posting these. I’ve never seen the effect of bezel color demonstrated so clearly.
The way the S2+ bezel is chamfered probably exacerbates the effect because of the angle the incident light is striking it.
