The corners are probably crushed when tightening the reflector. I had something similar in Convoy M1, also with luxeon v.
I didnāt mod a flashlight but I did change the oil on the truck today. Couldnāt find my filter wrench. Drilled a hole through the filter, put a screwdriver through the hole and loosened it that way.
Built a couple EDC carbon fibre spare cell carriers/ chargers.
CRX EDC Carbon Fibre 16340 Charger 700mA.
CRX EDC Carbon Fibre 10280 Charger 140mA.
CRX Utility Keyring - 47's Atom XHP50.2 3v, DQG Hobi+ 365nm UV & Petrol Lighter, 1.6W 450nm Blue Laser.
Hadnāt built a light in a while (weird huh?) so I put together a 17mm FET+1 and assembled an X6 from host stage with a 20mm Noctigon and Samsung LH351D W6 5000K emitter. Bypassed the spring in the tail and used a large Blue spring on the driver. Straightforward enough, right? Done this dozens and dozens of timesā¦ this time the driver blinked down to moon at level 4 of 7!
So I did the mod using two 2000 resistors and got it stable, makes 1460 lumens with a GA cell. Now the typically easy reversing doesnāt work properly. Wonāt work at all in the default mode and the medium press mode takes almost 4 seconds to shift it down. Have forgotten why this would be. Getting oldā¦
I hate those Easy Typical builds Iāve done several timesāespecially the ones I think are straight forwardāHow do they say that āIf it can happen,It will happen
Figures after I posted this ā Iām making some Trim for some Skylights I replaced(I have to match some trim I made 10 yrs ago) ā- started looking for a Round Over router bit(Iāve used this bit 1000s of times)ālooked all over in the case ā I have quite a few bitsā- anyway kind of had given upāthen Walla found it āstill in the router from the last time I used it ā I hope this is the extent of my excitement today āā
I have done that too. :person_facepalming:
I know this behaviour from lighted tail and bleeder resistor, but not without those. Perhaps you intruduced a ābleeder resistorā with an unwanted tiny solder bridge between batt+ and ground? You can check if the current is unusually high at moon setting.
Added an n52 3/4ā in. 1/16ā magnet to my zebralight sc64w hi. Super simple , sanded the endcap, magnet off eBay came with super thin adhesive. Peel and stick.
Thanks Jos, will open her up and check for that. And of course, once I read that I remembered similar behavior with the bleed resistor on the early ones. Just go blank these days and the info I am trying to retrieve eludes me.
No bridge, but I bet I know what I didā¦.
Would it act like that if I put the 10 Ohm C1 in the OTC position and the 1 Ohm OTC in the C1 position?
Iāve built literally hundreds and hundreds of drivers, itās astonishing how many times I forget what goes where. Seriously! If I donāt do it regularly I lose the infoā¦ like the girl in 50 First Dates. lol
Thanks for this, I have needed to do something like this for a long time and you just made it easy
So yes, I put the C1 and OTC on wrong. Just pulled both of them and replaced them with the correct new components and it works fine.
Duh!
Edit: Went ahead and bypass the blue spring on the driver with a 22ga turnigy wire, it makes 1510 lumens with either a Sanyo GA or LG MJ1 3500mAh cell.
DBC=back to his regular schedule
I have actually been contemplating boxing up the table full of gear and just stepping aside, at least for the season. By next Spring if I pick it back up Iāll have to start all over again.
With some 250 lights there isnāt much chance Iāll really need a new one anytime soonā¦
I have several coming in the mail, and my wife just told me something to the effect of ādonāt buy another flashlightā¦ or else!ā. I may find it necessary to make myself scarce for a bit.
Iām sure you already do this, but you can spread the light to family/friends to open up the shelf space. I got that 70% off coupon for the Sofirn SC31B recently and gave the light to my mother in law (lots of points for that move, and cost less than $8). I have had several requests from family members who have seen a light or two of mine, and I feel like that list will grow. This allows me to mod, and be generous as well.
Mods I have planned for the near future (waiting on the mailman and some slow boats):
AUX board for FW3CuTi (for me)
emitter swap on D4v2 to practice for D4v2Ti in transit (D4v2 for my brother, D4v2Ti for me)
Install pogo pins on HQ programming key and flash some E07s to the latest Anduril
Jaxman E1 build (possibly for my dad)
Convoy S2+ CU triple build (TBD)
Iāve been slowly selling/giving stuff away until something new and exciting comes along. Sort of just hanging back waiting for the next really interesting new advancement be it LED, battery, driver or a unique host of some kind (rotary, aspheric?). Weāll seeā¦
In any case no worries Dale, iāll PM you and try to suck you back in when something exciting comes along
Changed the lighted switch board on my modded Emisar D4v1 with lighted switch:
This is an Emisar D4v1 with Lexel lighted bezel board, a custom-lighted switch board, and firmware update for Aux-board control from the UI.
Previously, I had modded a Kaidomain lighted switch module and used that to illuminate the switch. However, I wasnāt happy with that arrangement since it only had 2 LEDs in it and they were slightly offset to the left side. I wanted the lit area around the switch button to be a solid ring of light. I redid the switch LED board as follows:
- The new lighted switch board involved no solder or application of heat. It is entirely handmade with all components attached with glue.
- I started with a piece of thin sheet plastic. I cut it into a ring with a hole in the center for the switch button.
- I then ran my super glue plastic activator pen over the plastic so super glue would stick to it.
- I made the traces for the LEDs out of conductive ink from a conductive ink pen. You can see the ink in the picture as it is black, while the substrate plastic board is white. The ink in the pen came out far too much and lacked precision, so I used the pen to put puddles of ink onto a piece of wax paper and then dabbed a sliced toothpick into it and used the toothpick to draw the tracesā¦ one outer ring and one inner ring, with appropriate cuts at each side for the positive and negative wires.
- I then installed the LEDs. These are 0603 blue leds. Hand-placed with tweezers so that each contact pad of the LED touches a different ring. The LEDs were glued in place with Fiberfix optical super glue (cures instantly when blue light shined on it). For ease of use, I mounted the entire board on a piece of double-sided tape on my work area before installing the LEDs.
- After each LED was glued, I used a cut toothpick to dab on conductive ink on each contact to give a good electrical connection.
- The base of each bondwire where it touches the inside edge of the board is glued, leaving the tip of the wire bare. Then I liberally slathered the exposed tips of the wires with conductive ink going to the traces.
- Initially, I started with 11 LEDs and 2 resistors on the left side of the board. The picture above without the cover on shows this version. However, I later decided that wasnāt bright enough and I wanted a more complete ring. I removed the 2 resistors and replaced them with LEDs. I already had a resistor between the MCU and one of the bondwires so the extra resistors on the switch board were not needed. I also added another LED on the bottom arc right side bringing the total to 14 LEDs.
- The switch cover is the same style as what Iād previously used. Silicone sheet with a small post on the bottom and a metal disk on the top. All glued with Fiberfix with plastic super-glue activator. The retaining ring is a filed down nickel-plated brass finished washer and is glued the same way.
- The light still needs a polish and wax and the silver-colored epoxy around the base of the retaining ring could use a bit of touch-up, but overall Iām pleased with how it came out. The body tube and stainless steel bezel are from a D4V2. The head, body tube and tailcap are aluminum with anodizing removed.
You would wouldnāt you C? Lol
Truthfully, Iāve been shooting all the flashlight money!
Nice conceptional work again Fl2! With a classy result!
Dang , thatās really nice , Firelight2 . Nice job .
