Holy Moly, 21amps even at 4 Volts is a lot. How fast does it termo regulate down? Few seconds? Did anyone measure the luminous flux? It could be very nice. If that is SST20 I am looking forward to how the XPL HI will turn out.
Yes, that is crazy. My convoy M3 draws only 10Amps. The step down is gradual, like a very slow ramp. After about 30 seconds it is back to same level as max ramp. Yes, this is sst-20. I wonder how long the turbo will be on the copper version. I have yet to program/change the step down temp settings
I bought a degausser for exactly that reason, My SKX007 was running fast when I bought it and it being magnetised was a possible reason for it, so I got that covered. :P
I've gone ahead & ordered a bunch of 25x2mm N50's anyway, if it comes to it I'll epoxy it to the outside of the cap, gotta haz me dems magical magnets. :LOL:
For those of you like me interested in the silver colour but confused about it’s true shade I found this picture online. Not sure but I feel it may more accurately depict the shade of silver than the Banggood pictures where it is darker.
I tested my MF01 Mini tonight and also got 21A turbo and 7-8A max ramp, on the Vapcell 5500mAh (Big Red) cell. The SST-20 4000K in this light is some of the best I’ve seen. Not even my FW3A or EDC18 SST-20 4000K models have such a good tint.
Excellent light… Will tune the Aux LED’s tomorrow night. That’s about the only thing I will “change” on this light.
HI mate, how to enable high settings for the Aux LED? Also, can you help me set my aux to blinkinking mode? The manual did not specifically says how except for 7 clicks on off and 3 clicks on lockout mode. Thank you so much.
Mine came with the AUX LEDs set too dim to see on the low mode. Had to take the top off and adjust the trimmers.
Just gently turn each one to see what it does then return it the original setting.
Once you know what each does adjust them how you want.
I’m sure there are instructions in here somewhere but they can be hard to find.
I prefer to change the settings in lockout mode at first as it’s easier. Once you know how, do the normal mode.
Off - 4 quick clicks for lockout then 3 quick clicks advances to the next mode each time you do it. That sets the AUX LED mode in lockout.
Off - 7 quick clicks in normal mode advances the AUX LED mode each time you do it. That sets the AUX LED mode in normal operation.
Thanks for sharing!!! I have been tempted to go for the Mini in silver as I really liked how it looked in the Banggood pictures where it has a darker, richer look. However another picture online showed it to be much a lighter silver which I too thought looked “cheap”. Your confirming this has saved me the disappointment I think you feel. Hope you find someone you can sell/gift yours to and then pick up a better colour. I’m going to finally pull the trigger on the gun metal grey.
