Loneman
(Loneman)
October 20, 2019, 4:01pm
1215
I bought a degausser for exactly that reason, My SKX007 was running fast when I bought it and it being magnetised was a possible reason for it, so I got that covered. :P
I've gone ahead & ordered a bunch of 25x2mm N50's anyway, if it comes to it I'll epoxy it to the outside of the cap, gotta haz me dems magical magnets. :LOL:
rbpinto
(rbpinto)
October 20, 2019, 4:02pm
1216
For those of you like me interested in the silver colour but confused about it’s true shade I found this picture online. Not sure but I feel it may more accurately depict the shade of silver than the Banggood pictures where it is darker.
KevinZA1988
(KevinZA1988)
October 20, 2019, 7:12pm
1217
ver_ivanz007:
Here are my measurements:
All AUX LEDs at max brightness - 15 to 18mA - it means it will drain the a 5500mAh battery in 305 hours
if I set the green at max brightness, the blue and purple LED will not turn on at low AUX mode. Green LED need to be adjusted down a bit for the blue and purple LED to light up at low mode.
Max Ramp tail cap current - 7-8 Amperes
Turbo tail cap current - 20 to 21 Amperes on a freshly charged Vapcell 26650 5500mAh battery. This is one of the highest tail cap measurement I have so far.
One thing I noticed is that the battery voltage indicator is off by 0.2 volts. When I placed a 4.2V fully charged battery, it only blinks out 4.0V. I also saw this on my sand and gray colored light. Do you guys also noticed this issue?
I tested my MF01 Mini tonight and also got 21A turbo and 7-8A max ramp, on the Vapcell 5500mAh (Big Red) cell. The SST-20 4000K in this light is some of the best I’ve seen. Not even my FW3A or EDC18 SST-20 4000K models have such a good tint.
Excellent light… Will tune the Aux LED’s tomorrow night. That’s about the only thing I will “change” on this light.
patmurris
(patmurris)
October 20, 2019, 8:48pm
1218
Thanks! It worked. One Al/Cu 40000K on the way… :heart_eyes:
jmd4tide
(jmd4tide)
October 20, 2019, 9:14pm
1220
Send me the coupon please!
KevinZA1988:
Nice. We got the same results. Mine was SST-40 6500K. I’m still waiting for the 4000K Cri 95 version.
HI mate, how to enable high settings for the Aux LED? Also, can you help me set my aux to blinkinking mode? The manual did not specifically says how except for 7 clicks on off and 3 clicks on lockout mode. Thank you so much.
JasonWW
(JasonWW)
October 21, 2019, 10:17am
1223
With the light off, have you tried 7 fast clicks? I think that should switch the aux lights to the next mode.
Down_South
(Down_South)
October 21, 2019, 11:06am
1224
I have one of the MF01S and the Mini in Silver.
Where the full size is anodized so it looks light silver gray and expensive the Mini is stark aluminium.
It’s like the difference between a satin and high gloss paint.
It’s even more pronounced than the BLF A6 SE non anodized which I like and still carry. The knurling on the A6 is tighter so less shine.
The Mini in silver looks CHEAP and on mine you can see the grinding / buffing marks. Definitely non anodized aluminium.
Looks like crap, works like a dream except the battery voltage reading is .5v too low. fully charged 4.2 v reads 3.7 v.
Charging circuitry works correctly for the 26650 that comes with which measured 5670 mah on my Opus 3100 V2.2, a Samsung 40T and 30Q.
Mine rides in a Ultrafire holster I picked up at Banggood years ago for my BLF X6 SE/Astrolux S2 which is still in the box.
Down_South
(Down_South)
October 21, 2019, 10:30am
1225
Mine came with the AUX LEDs set too dim to see on the low mode. Had to take the top off and adjust the trimmers.
Just gently turn each one to see what it does then return it the original setting.
Once you know what each does adjust them how you want.
I’m sure there are instructions in here somewhere but they can be hard to find.
I prefer to change the settings in lockout mode at first as it’s easier. Once you know how, do the normal mode.
Off - 4 quick clicks for lockout then 3 quick clicks advances to the next mode each time you do it. That sets the AUX LED mode in lockout.
Off - 7 quick clicks in normal mode advances the AUX LED mode each time you do it. That sets the AUX LED mode in normal operation.
JasonWW
(JasonWW)
October 21, 2019, 10:40am
1226
Why do that when you can just switch them to the brighter option with 7 fast clicks?
There are trimmers on the board that are labelled, you need to adjust them with a small screwdriver
Danke, ja super, harr, ist es dann vll Die Eine Lampe? Auf Die ich mein ganzes Leben gewartet habe? Fehlt nur noch ne Throw Led in der Mitte mit Zusatztaster fürn Spot, gibts sowas überhaupt? Schwierig mit dem Reflektor...
Translation:
“It even says it on the board:
‘Low’ for red
‘High’ for green
D1 blue
D2 pink
Unfortunately Astrolux set the trimmer values far too high and the LED resistance too low, it’s hardly possible to set up ‘bright’.”
Down_South:
That makes me glad that silver was unavailable when I ordered mine, so I just chose plain black, same as my MF01s.
Down_South
(Down_South)
October 21, 2019, 11:30am
1228
I’d say “If they can’t see you they can’t shoot you” but then I’d have a different flashlight. Actually . . .
Because I prefer the low mode as it’s plenty bright to find the switch. My way, if for some reason I want the high I can choose it.
Wish the AUX LEDs could be off with just the switch lit. High, low, breathe, off.
Life’s about choices. I like all I can get. It’s why I left the USA years ago.
Little freedom left there when I left and none now so I’m told by almost everyone returning from there.
That’s what I hear every time I go to the local VFW for some beers and talk.
Down_South:
Oh no. It looks like I have to cancel my silver order if possible and just go straight to full copper.
I also have same issue with the voltage indicator. Mine is 0.2V off.
rbpinto
(rbpinto)
October 21, 2019, 11:52am
1230
Down_South:
Thanks for sharing!!! I have been tempted to go for the Mini in silver as I really liked how it looked in the Banggood pictures where it has a darker, richer look. However another picture online showed it to be much a lighter silver which I too thought looked “cheap”. Your confirming this has saved me the disappointment I think you feel. Hope you find someone you can sell/gift yours to and then pick up a better colour. I’m going to finally pull the trigger on the gun metal grey.
patmurris
(patmurris)
October 21, 2019, 1:11pm
1231
Down_South:
This sounds good news to me! I loved the bare al A6… and was very disappointed by the clear ano L6 which looked like a fake silver plastic toy to me.
Yes I did the 7 clicks a number of times but the aux lights remain still.
